Valve Springs?
LS1 97-04 PN 12553696 natural color
LS6 02-04 PN 12553696 yellow color
LQ4 99-04 PN 12553696 natural color
LQ9 02-04 PN 12552696 natural color (common to LS1 PN 12553696)
So what is the actual difference except the color? Are they actually all the same spring just different colors?
I am putting a LS6 cam in my car and worder do I really need to change valve spings?
There are also tons of people selling crappy LS1 cams as "LS6" cams, beware. Even if you do find a true LS6 cam, there are two versions "2001 385hp" and "2002-2004 405hp" version. Check the back of the cam for the four digit part number and check it against this site to see what cam it actually is. http://chevythunder.com/LS1%20components.htm.
The LS6 cam needs at least the LS6 springs (Yellow). But I agree that aftermarket cams and springs are much better for making more power. Comp Cams #26918 are a great spring. I run them on almost everything I build, including my own truck.
