How do I remove Piston from the Rod?
Old Apr 3, 2010 | 11:04 PM
98 WS6's Avatar
Default How do I remove Piston from the Rod?
Hey guys,
How do I go about removing the pistons from the connecting rods? I've read a few things that a machine shop has to press them in..
Is there a way to do it yourself?
Thanks!
Old Apr 3, 2010 | 11:09 PM
bossz28-1's Avatar
u can build ur own press using a bottle jack and welding some metal together
Old Apr 4, 2010 | 01:57 AM
jkkaz's Avatar
Originally Posted by 98 WS6
Hey guys,
Thanks!
By a press. I bent a 10ton and now have a 20 ton. Harbor frieght stuff works just fine. I bent the first press doing something with another car. Rods should be pretty easy since they don't get all rusted out. I've also done it with a big vise before, but nice ones cost as much as cheap press and I wouldn't skimp on a cheap vice. I've broken one of the cheap chinese made ones before when it should not have broken.
If you don't like the price of a press, send it to machine shop.
Old Apr 4, 2010 | 02:03 AM
negativeswitches's Avatar
be carefull if your going to reuse the pistons
they make a special fixture for pressing out piston pins in a press
Old Apr 4, 2010 | 09:37 AM
greatskiiiier's Avatar
you need a press and the fixture, then when you want to put the piston back on you just heat up the rod
heres some pics of the fixture
http://www.60degreev6.com/pics/TSB/TSB066.gif
http://www.garage411.com/images/Gene...PinInstall.gif
not to upset the mods, but this looks exactly like what you need- http://www.goodson.com/store/templat...l.php?IID=5103
Old Apr 4, 2010 | 09:45 AM
Justus67's Avatar
Harbor freight, cheap and easy.
