799 heads. what gaskets?
Old 04-04-2010, 11:22 AM
brian_rs/ss's Avatar
Default 799 heads. what gaskets?
ok just purchased a set of 799 heads off of the classifieds, i would like to know what head gaskets you guys are running and also how thin can i go? i would kinda like to be able to pick up a wee bit of compression if i can't get them milled.
the smallest summit carries is a .045 set of trick flow MLS gaskets for $72. i'm still searching around though.
Old 04-04-2010, 11:27 AM
ok jegs has a set of cometic .027 gaskets for $90. that seems kinda steep though. but is that too thin?
Old 04-04-2010, 11:30 AM
PREDATOR-Z's Avatar
Yes that is too thin for street. The .045 gasket or .040 would be better
Old 04-04-2010, 11:33 AM
ok kool, you by chance have any idea what comp. ratio a .040 gasket would give me with untouched 799's?
Old 04-04-2010, 11:36 AM
PREDATOR-Z's Avatar
~ 10.9:1
Old 04-04-2010, 02:43 PM
ok thanks predator! sorry for the dumb questions.
Old 04-05-2010, 09:00 AM
BOTTLE ROCKET's Avatar
Where can you pick up a set of .40 mls gaskets (part #?)
Thanks
