What Head Gaskets?
Old Apr 5, 2010 | 07:08 PM
70TWO NOVA's Avatar
Default What Head Gaskets?
Im building a 5.3l with a set of 217 heads milled .030". Can I still run the stock 5.3 head gasket with these heads or do I need a head gasket with a larger bore since the heads are off a 6.0 with a 4" bore? Anybody know or have the part numbers of what gaskets I would need?
Thanks
Old Apr 5, 2010 | 08:41 PM
oldguy99Z's Avatar
If your heads combustion chamber is 4" then you need a head gasket with at least 4" bore- gasket must be as large bore as the larger of either the cylinder bore or the combustion chamber.The GM LS2/6.0L gasket would work fine.Sorry but I don't have the part #.
