HELP me diagnose leak down results
BTW: I used a MAC tools leakdown tester with 2 gauges. It look approx 40 psi to zero the first gauge before starting the test.
Procedure:
1) pulled all plugs
2) Pulled valve covers
3) Removed Rockers
4) Blocked open throttle blade
5) Pressurized one cylinder at a time and recorded percentage leakdown.
Results:
Drivers side front to back: 1= 30%, 3= 28%, 5= 88%, 7=86%
2=20%, 4=22%, 6=24%, 8=22%
could not hear any major air escaping through intake or exhaust, also no bubbles in coolant. #5 and #7 plugs were also BLACK. But all the plugs had a little bit of oil around the threads.
Any help or direction would be greatly appreciated.
my question is, why did you remove the rocker arms? you should have left everything alone, VC's excluded, this makes it easier to hear air going through the crank case/valve seals, brought each piston to TDC on compression then did the leak down.
I'm questioning whether the leak down is being done right if you cant easily trace that much of an air loss.
I wouldn't throw in the towel just yet....more digging is certainly in order
-Tony
Just pull it all apart and rebuild it.
None of this would account for your results, though, so good luck w/ the rebuild.
