cleaning deck surface before new head gaskets?
Old Apr 28, 2015 | 02:31 AM
Jontall's Avatar
Scotch brite leaves an abrasive residue behind, so you need to be sure to wash the heads very well after cleaning. http://www.bobistheoilguy.com/forums...&Number=563163
Old Apr 28, 2015 | 02:39 AM
HISS's Avatar
Scrape the big stuff off first. Stuff some lint free clean rags in the cylinders and lightly scuff the surface with the least abrasive roloc disc on a die grinder.
Old Apr 28, 2015 | 06:34 AM
redbird555's Avatar
use some permatex gasket remover then the plastic razor blade. the permatex will dissolve a lot of the old stuff and loosen the rest for the razor blade. usually takes me about 20 min for both sides
Old Apr 28, 2015 | 06:45 AM
wayland1985's Avatar
Any worry with where you spray the permatex? Places to tape off?
Old Jun 2, 2015 | 04:47 PM
Very slow-going... I'm using the gasket spray and plastic blades. Seems I may be here a while...
Old Jun 3, 2015 | 06:47 AM
gagliano7's Avatar
All I can say cleaning off the gaskets sucks and I only had to clean my iron block. I used gasket remover and razor blade which worked the best then I block sanded the deck with 400 grit soaked in wd-40. Came out nice and smooth. I also used a straw taped in my shop vac hose to clean out the bolt holes. That was the best thing for the holes and only took 5 minutes and holes were clean and dry.
