what do i need to swap to a ls6 intake?
Old Apr 12, 2010 | 03:36 PM
bigc98ws6's Avatar
Default what do i need to swap to a ls6 intake?
what parts do i need to swap to a ls6 intake i heard u need some coolant lines but not sure?
Old Apr 12, 2010 | 04:35 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
You don't need the LS6 coolant setup. You can remove the ribs on the bottom of the LS6 intake. DON'T break the oil pressure sending unit
https://ls1tech.com/forums/generatio...s6+intake+swap
https://ls1tech.com/forums/generatio...ntake-fit.html
https://ls1tech.com/forums/generatio...-searched.html
Old Apr 13, 2010 | 05:25 AM
bossz28-1's Avatar
u need some sort of block off plate were the egr bolted to the exhaust
