Ported heads?
Old Apr 12, 2010 | 07:07 PM
sslateron's Avatar
Default Ported heads?
How much power would a built 383 make with ported Ls1 heads, an. Torquer 2 cam, and a Borla exhaust?
Old Apr 12, 2010 | 07:51 PM
Austinma62's Avatar
Try a search man. I think there is a guy who has a 383 ls6 block, prc 215 heads, torquer v3 and fast 92 intake. The guys name was HondaNick. I found it by searching 383 in the dynamometer section.
Old Apr 12, 2010 | 07:52 PM
Austinma62's Avatar
His numbers were 482/458 with a broad torque curve!
Old Apr 12, 2010 | 08:21 PM
sslateron's Avatar
Are prc heads ported ls1s?
Old Apr 12, 2010 | 10:45 PM
sslateron's Avatar
ttt
Old Apr 12, 2010 | 11:01 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Depending on the port job, it could be fairly close to a number like mentioned above. If the heads arent milled and exhaust ports arent polished it could be completely different.
If he is refering to the aftermarket casting Precision Race Components 215 heads then you will probably be behind on your number.
Old Apr 13, 2010 | 05:15 PM
sslateron's Avatar
You guys weren't very helpful on this...
Old Apr 13, 2010 | 05:52 PM
garygnu's Avatar
yes PRC are ported ls1 heads.check TSP for a 383 package,or check the parts classified for 383.
Old Apr 13, 2010 | 06:28 PM
sslateron's Avatar
Ok cool, then this should be making some good power then.
