underive pulley adjustment???
Old Apr 13, 2010 | 01:17 AM
kru510's Avatar
Default underive pulley adjustment???
so I am finally putting on all my accesories and for some reason the underive pulley doesnt line up with the tensioner,power steering,and alternator. I am running the slp underdrive pulley. Now my question is ...does the pully need to be adjusted or something. I have never installed this type of pulley. I am kinda of looking at it and I think I need to take out the oversized c clamp and adjust. opinions please? I was thinking they sent me the wrong pulley..but the hub is the same as stock thx
Attached Thumbnails underive pulley adjustment???-pic_0438.jpg   underive pulley adjustment???-pic_0439.jpg   underive pulley adjustment???-pic_0440.jpg
Old Apr 13, 2010 | 01:23 AM
Squirts11's Avatar
What do you mean it doesn't line up? Do you mean it isn't aligned with the other accessories enough to allow the belt to fit correctly? Or do you mean the belt length isn't correct?
Did you get the new (shorter) belts necessary when an underdrive pulley is installed?
Was it fully seated against the crank when you checked its alignment with the other accessories?
Old Apr 13, 2010 | 01:29 AM
kru510's Avatar
it doesnt line up with the accessories at all to fit a belt. And it was fully seated on the crank.
Old Apr 13, 2010 | 01:31 AM
Squirts11's Avatar
That's very unusual. Someone with a SLP underdrive pulley will need to chime in, as I've never heard of this before.
Old Apr 13, 2010 | 02:44 AM
kru510's Avatar
im thinking i may have gotten the corvette ls1 version and not the f-body. This for an 1993 rx7. I bought an ls6 with no accesories and had to add all the accesories myself.
Old Apr 13, 2010 | 05:04 AM
bossz28-1's Avatar
that looks like it fits a l76 in the g8's
