ported throttle body
Old Apr 14, 2010 | 05:21 AM
trans_am7935's Avatar
Default ported throttle body
is there a difference? is it worth spending 60 bucks over? i have an LS6 intake longtubes offroad y-pipe and supporting mods. should i get my stock 75mm ported or should i get a 80mm and port match my LS6?
Old Apr 14, 2010 | 08:59 AM
JasonSS2000's Avatar
A good hand ported unit will show good throttle response improvement, but no real power gains. A CNC spiral ported unit will give both with a 6-8 rwhp gain.
Old Apr 14, 2010 | 09:35 AM
SWEET98SS's Avatar
Search under new era performance, they did a test a couple years ago on there porting, it was like 6-7 rwhp. They do them now for $75, pretty good deal
Old Apr 14, 2010 | 09:36 AM
ska4life07's Avatar
I ported the stock TB and it gave way better throttle response. Though, if I had the money then I would just buy a bigger one to match the intake.
Old Apr 14, 2010 | 11:15 AM
Red99TA's Avatar
Ported TB is definitely worth a few HP and as mentioned better throttle response plus it's cheap. However if you're going to go to a 90 or 92mm FAST in the future I probably wouldn't waste the time on a ported stocker - put the money towards the 90/92mm fund.
Old Apr 14, 2010 | 01:23 PM
Paint_It_Black's Avatar
It's worth up to 100 cfm I believe if done right?
Old Apr 14, 2010 | 02:18 PM
Duffster's Avatar
Please tell me you're kidding. . . .
Old Apr 14, 2010 | 04:25 PM
No?
This is from a rep at TPIS when asked about their 75mm TB's:
- the 75mm throttle body flows 910 cfm
- the IAC port on the intake remains intact and functions like stock
- the two tubes on the passenger's side (fresh air and EVAP) are deleted
- there is enough "meat" to bore it to 78mm and get 1,050 cfm
140 cfm to be gained from from a 3mm bore. I know the LS1 TB's are risky to take to 78mm, so staying safe would still get you close to 100cfm. Granted the stock TB is not designed like a TPIS TB.. but if you know what you are doing and as someone who was good at these said, "enlarge the "venturi" right before the throttle plate, and the rest of the bellmouth is reshaped/filled." then yeah, you should pull close to 100cfm more.
Old Apr 14, 2010 | 10:13 PM
BriancWS6's Avatar
That's complete bullshit.
I tested the VERY first unit I ever ported several years back and it gained between 6-7rwhp and 5-6rwtq along with improved throttle response.
Old Apr 14, 2010 | 11:12 PM
stangtrader's Avatar
i personaly wouldnt spend the money,if any thing i would do it my self again. its not relly hard you just need to take your time and pay attention.i did mine in about a hour.do a google search there is a good link for a how to.or pm me and i can send you the link.
Old Apr 14, 2010 | 11:59 PM
Duffster's Avatar
No?
IF you bore out the throttle body by 3mm and use the same 78mm butterfly, you'll have more problems than you want... low vacuum, ****-poor idle (unless you like to idle above 3500 rpm)...
You have fun w/that
Old Apr 15, 2010 | 09:43 PM
BriancWS6's Avatar
When porting the stock throttle body, you do NOT change the diameter where the blade/butterfly is. This area is left 100% UN-TOUCHED. What you are doing is removing the ridge in front of the blade, and opening and smoothing the path from in front of the blade to the outside edge.
Old Apr 16, 2010 | 09:29 AM
Duffster's Avatar
and you're still not going to get near 100+cfm gain
Old Apr 17, 2010 | 07:45 PM
BriancWS6's Avatar
I never said anything about cfm gains. I just know they will make more power and improve throttle response.
Old Apr 17, 2010 | 07:49 PM
madmike9396's Avatar
anyone have a link on how to do this ? i am bored and might take mine off and get the dremel out lol
Old Apr 17, 2010 | 10:13 PM
brooknasty's Avatar
just grind that thing out but don't grind around the throttle blade. make it nice and smooth with fine sand paper and you are done!
Old Apr 17, 2010 | 10:42 PM
Squirts11's Avatar
Installuniversity.com
bowlingss.com
Both have write-ups on DIY throttle body porting.
