where to get a set of .019 main bearings?
i have looked around and have found them only for sbc.
anyone know where to find some. thanks!
Two other options. Get your bearings coated at Calico, Polydyne, etc. or close up the housing bores a thou to tighten the clearance.
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Short answer, no you can't polish the crank a thou. You would never get the journals round, without a barrel shape or taper.
Torque up the mains and check the housing bore in the block with a dial bore. See what you have for size. These engines need the main bearing bore size at the high limit of 2.7515" or you end up having too tight a clearance. For example, at 2.7509" the low limit, with standard size crank you end up needing two sets of mains to get the correct clearance. One set std. and a set one over, half a set of each.
If the crank is ground to the correct size, I think you will find the housing bores are on the tight side. Align honing the block to the high limit should get the clearance where you need it to be for your .020" under bearings.
Steve
Steve Demirjian
Oceanside, Ca.
760-630-0450
