LS1 at the machine shop
Old Apr 23, 2010 | 09:30 AM
Mkelcy's Avatar
To answer your original question, I'm building a similar 3.905" bore LS1 using Mahle forged, coated pistons designed to be used with stock rods (Part No. LS1340905F04 - $500 from Flatlander Racing), and stock LS2 crank and floating pin rods (which should be readily available used). Everything I've read indicates that the stock pieces should be able to easily handle any level of power you can make in a NA engine.
Old Apr 23, 2010 | 09:33 AM
Ryneman's Avatar
Thanks Mkelcy, the LSX guy is going to call me and tell me what kind of pistons I want. I told him the best pistons for that engine. When I talk to him again, I will tell about the Mahle.
Old Apr 23, 2010 | 01:53 PM
1CAMWNDR's Avatar
They needed to grind the crank?? I have only ever heard of one needing to be polished. Was the crank really scored up?? Maybe they really only did a polish and mistakenly said they ground it.........
Old Apr 23, 2010 | 04:49 PM
KCS's Avatar
KCS
Moderator
Originally Posted by bww3588
you dont need the pistons to bore it.
Who said you did?
Old Apr 24, 2010 | 02:32 AM
bww3588's Avatar
Originally Posted by livefast1
you should be alright, if you haven't even ordered the pistons yet i doubt they've bored it already. but yes if they didn't KNOW you can't bore a ls1 .030 over i would be leary of letting them do the work.
Originally Posted by KCS
Who said you did?
Old Apr 24, 2010 | 05:29 PM
KCS's Avatar
KCS
Moderator
I guess I can see that interpretation, but that may be reading into it too much.
Old Apr 24, 2010 | 05:35 PM
KCS's Avatar
KCS
Moderator
It might be a preference thing. I usually prefer to have a crank ground so I know it's straight and round, especially a used crank. Also, that way I can order one set of bearings, and set bearing clearances where I want it. However, it seems they're grinding the crank before they get rod bearings...odd.
Old Apr 25, 2010 | 08:56 PM
Ryneman's Avatar
They already have the rod bearings and pistons.
