Roller Rockers?
Ive tested a 525fwhp, very small solid roller, ETP 225 heads, 5.7L and made a 15hp gain by switching from 5/16" .080 to 3/8" .080. But ET heads have longer heavier valvles that makes valvetrain control a little harder. On the same engine I also swapped from stock rockers to shaft mounts and lost a few HP, most likely because they were heavier and had a worse MOI.
What we really need is someone with a Spintron to do a pushrod test. If the engine is up and running already, doing the entire test would take a few minutes of added time.
Tomorrow we do the Dyno tune and I'll be posting numbers with the dyno sheet.
