Am i F***ed? Spark plug issue
these are TR-6, N/A.. no spray
this is a decently modded motor. i WAS running cobra 39#ers. swapping to some rebuilt 42#ers now.
dude if im good to go thats awesome news.. definitly learned my leson
Why wouldn't the same results happen again with a "tune-up" and a new plug?? What has changed to prevent that from happening (answer....nothing)
Obviously its lean and very likely detonating in the number 7 cylinder which has been the death knoll for more LS engines than you can shake a stick at.
Do you have irreversible engine damage now? Probably not, but get on the chassis dyno (or street with a wideband) and check your timing and A/F ratios and if your borderline fatten it up some and reduce some ignition timing.
What if the current tune is 31 degrees of lead and your A/F ratio at 6500 is 14.2 to 1
Tune up or no tune up you will rattle and loose that plug electrode again of your lucky....if your unlucky a piece of the #7 ringland will come off the next time along with it.
Address the problem....without doing so the same end results or worse are inevidably going to ruin your day
-Tony
the tune was fucked for a while, and the car sat for about a year.
this time the fueling will be dialed in before its blindly tuned and VE/PE tables are "raped" as some would say
