Need Help diagnosing a knock. Vid inside.
Have you checked your rocker arms? I took mine off and hand rotated each one. It turned out that 3 of the 16 were 'not right'. They were tougher to turn. The rocker should spin effortlessly on the trunion. I recommend starting there since they are so easy to access. I'd also check all pushrods for straightness while they are out.
If those two items are fine, then you might have to look into bearings- cam/rod/main. I don't know what else it could be.
Good luck
Good luck
