Ls crank question
Old Apr 26, 2010 | 09:59 PM
Dtown_Slim's Avatar
Default Ls crank question
Will an Lq4 crank work in an ls1?
Old Apr 26, 2010 | 10:14 PM
Texas_WS6's Avatar
What year crank is it?
Old Apr 27, 2010 | 02:01 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
You need to ensure the truck crank does not have a thicker rear flange than the LS1 did. Certain truck cranks did and that would be problematic!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 27, 2010 | 05:13 PM
bww3588's Avatar
casting number 216 was the shorter crank (LS1 length) and 215 was the longer truck style.
the only difference between a 216 truck (5.3, 6.0) and the 216 (LS1) is the LS1 crank has been gun drilled. other than that, they are identical.
Old Apr 27, 2010 | 05:14 PM
bww3588's Avatar
and just so you know, the only years for the 215 crank was 99-2000 6.0 engines. 2001 they went to a shorter 216 crank with a spacer.
Old Apr 27, 2010 | 05:59 PM
Good info, bww! Thanks for sharing that!
__________________
Old Apr 27, 2010 | 06:06 PM
bww3588's Avatar
no prob matt...
