Calling all cam Guru's - Ideas for daily driver (243s/rod bolts/willing to flycut!)
241 heads so if you go with the 243 you will have better flow and thus more hp. Remember 59cc chambers are 59CC chambers regardless which head you are looking at. It takes more to get to the 59cc chambers on the 241s but compression should be around the same 11.5:1. 93 octane is best to be used with such heads anything less like 91 your going to have to start to pull a fair amount of timing.
Either way, it sounds like a huge cam may not be the best route for me, but it's just so enticing to want the best possible gains for the time/money spent. Perhaps the mid-sized (low 230s) might be more along the lines of what I should be looking towards.
LSX Mechanic
Talk to Geoff about the 226/236. Anything smaller than that isn't going to be worth the effort over your current cam.
Also, 02*C5 got lucky with his car that he didn't have to flycut. Don't use his setup as a rule of thumb for PTV like he does.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
As a matter of fact, don't use any car you read about on the internet as a comfort factor on whether you do or don't have to flycut. Generally, anything over 232 degrees duration needs to be checked when paired with a cylinder head ran below 61cc.
I've got a 234 lobe on a 107 icl with 58cc heads. I have to cut almost .100 out of the piston for the intake.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
anything else and you start getting into the 230s...225/230, 229/235, 231/236, 232/238, 233/239... and all the mentioned end up with a 600+ intake or exhaust lift or both in and out @ .600+ lift or bigger than the op wants, or then you have to go custom which would be my choice.
#32
Based off what I have seen with the AZPS02 cam (02*c5's set up), I would go with that if you can find it (obviously check PTV), or a similar type grind. For the heat and crap out here in AZ, his car does well, and though I have never rode in it, I have only seen him drive that car, and seems to be fine driving anywhere with good street manners.
#33
Its descent size cam w/ a .588 lift and you can get it in any lsa you want. Exactly what the op is looking for not big or radical. why not for N/A specially if you get it in a 110-112 lsa?
I also know you can't randomly choose LSA and have an optimal cam.
#34
Hmm...while I did say that the car is my daily driver, I'm wanting this next cam to be a considerable jump over my current grind (see sig). Considering I'm installing Katech rod bolts and willing to flycut, I wouldn't necessarily say that I'm looking for a "mild" build.
I think I'm looking to find a balance between the typical mild cam (228R) and the typical giant cam (trex). I probably will end up going custom, but am very interested to see what inforamation the masses here have to offer, as this site has quite a few knowledgeable members.
#36
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
#37
Honestly, I don't think it makes sense financially to swap for something as mild as the 228, like Damian was saying earlier.
