Pushrod worn down..
Old Apr 28, 2010 | 04:59 PM
Screamin LS1 SS's Avatar
Default Pushrod worn down..
I bought this 01 Trans Am. The car has long tubes, bolts ons, and some heads/cam work. I don't know anything about it because I bought it from a bank it was a repo. It was making a noise from the top of the engine. The car backfires and has a loud tapping noise coming from the top of the engine but actually runs pretty good and holds good oil pressure. I thought a pushrod was bent but it sounded louder than what I normally hear out of a bent pushrod. Anyways...we pulled all the pushrods and the first one on the right side is worn down right toward the bottom. You can tell in the picture where it is worn at. What could cause this??
Old Apr 28, 2010 | 05:10 PM
01ssreda4's Avatar
You talking about the silver area? Its rubbing the hole in the head as its moving up and down. It could be flexing or the hole/pushrod could be an incorrect diameter.
Old Apr 28, 2010 | 05:21 PM
Yes, the silver area. You can feel that it is worn down through the silver area.
Old Apr 28, 2010 | 06:36 PM
01ssreda4's Avatar
Its from rubbing the cylinder head
Old Apr 28, 2010 | 07:08 PM
What would cause that? Could it cause a loud tapping noise?
Old Apr 28, 2010 | 07:26 PM
vettenuts's Avatar
Can you see anything down the lifter hole? Since that is the bottom, not sure it would hit the head as it looks to close to the lower end but honestly hard to tell via photo. I would try and examine the pushrod hole as best you can, a boroscope will help if you can get your hands on one.
Old Apr 29, 2010 | 07:08 AM
01ssreda4's Avatar
OP, you sure it didnt get turned around, you sure this isnt the top of the pushrod??? Im talking about how it was placed in the engine, the silver worn area was obviously facing upward.
Old Apr 29, 2010 | 04:38 PM
vettenuts's Avatar
That would make more sense but the first post says bottom (had to re-read, getting old you know )
