what happened to the LS1 I bought - #7 piston busted
when my motor did that it didnt burn oil but fuel got into the oil... was wierd. till i pulled the heads off i mean. Did it in 7. sam **** only on the very top of piston. didnt hurt the heads. Detonated off....
I don't wanna sound like a moron, but would this type of damage show up if a compression test was done on a motor? Just curious because I picked up a 60K mile 2001 LS1/A4 the other day. Compression checks were all around 185-195.
I'm wondering if its a good idea just to pull the heads to be sure? Or should I not worry about it because of the compression tests results?
Now, people will tell you that it's always a good idea to tear down a junkyard/used motor, and no one will tell you that you should pull a junkyard motor and run it in whatever car you want to put it in.
No one will ever tell you that, BUT people do it, and it turns out fine. Having said that, you don't know if anyone's run nitrous through a junkyard/used motor, or ran low octane gas when they should have run higher octane gas, etc.
It takes a little time (and money since you have to get new head bolts) to pull the heads on a used motor, but it's never a BAD idea to do so.
I'm glad I pulled the heads on mine man. A broken piston sucks, but it could have been way worse. I just put the oil rings and piston rings on the new piston and the machine shop already hung the piston on the rod, so I'm about to clean the deck surface and the head surface and put in the new piston.
I think the broken piston piece DID go out the intake, because there are some weird scratches around the cathedral port. Nothing that would cause sealing issues with the intake manifold; it just doesn't look normal.
Moderator
If it's a bunch of pieces, then the chances should be better that at least one of them would have been left behind, or at least leave evidence, like a marking or something. To have them all leave out of the exhaust valve all nice and neat just doesn't seem likely. Not to mention, it would have to travel across the cylinder to reach the exhaust valve, when the intake valve and quench pad are right above it.
Moderator
I have a 2005 CTSV. I had installed a Fast 92mm, NW 90mm ported TB, TFS 215cc heads, headers and all the usual boltons. The car was around 480 rwhp on the stock longblock. The AFR was in the 12.7 range and timing was 24 degress. After about 20,000 miles with the head, cam and intake, the engine started burning oil and smoking. Tore the engine down and you could move the #7 piston around in the bore with your thumbs. All other cylinders were tight and in good shape. I didn't have anything broken like the piston or rings. It just looked worn out. The shortblock was factory and only had 46,000 miles on it. Just put in a forged 408 shortblock. Will see what happens now.
Well guys, I got a new piston and went to go install it today. Can't believe I didn't notice this before, but check this out, looks f'd up:
This is the #7 cylinder bore. I have no idea if that's fixable or not. Ran my finger over it and you can definitely feel a change in surface. Not comfortable putting that piston in now.
So now I'm trying to think of what options I have. So far I've come up with these options:
1. Tear everything down, take it to a machine shop, see if they can repair it and if so, pay the $$ and put everything back together.
2. Tear everything down, find a good stock block that's got good 8 cylinders, and swap everything over to it.
3. Start completely over with a new LS engine.
4. Give up and sell everything.
I feel like total **** right now because it feels like I'm basically one cylinder away from having a good daily driver muscle car.
Anyone else have any other options? Thanks guys, I appreciate the advice.
#33
Hmmm...would a flex hone help before taking it to the machine shop (I've never flex honed before)? One of these:
I heard flex honing doesn't change the bore diameter, so I should still be able to use the stock piston/rings, correct?
#34
Moderator
Maybe not. In a rigid hone, like at a machine shop, if it's cracked it would leave a shadow where the stones didn't touch. A flex hone is designed to conform to whatever shape the bore is in, so you won't get that same effect. It'll just clean up the cylinder, but that's what the rigid hone is going to do anyways.
#36
KCS can probably confirm this.
#37
Moderator
Flex Hones can restore surface finishes on a cylinder wall for a new set of rings to seat. It's not going to change the bore geometry, or remove enough material to use a larger piston, but it can be used just to get a nice new surface finish for a rebuild.
Also, yeah a .005" over piston probably will throw off the balance a considerable amount. Not necessarily because it's a larger piston, but the material is different and can be heavier itself.
#40
I was told that it's because of the intake manifold design. #7 is the last to get air, the air is denser, and this creates a lean condition. Increase the heat a little, or clog your #7 injector a little, and your #7 piston goes at the ringland.
