Tech gods old schoolers ...Anyone
Head gaskets
Water pump
New Hyper tech 160 thermostat
Just got it all finished and same problem
I tore it down thinking it was head gasket had block and heads checked ...all good!
I am sitting here right know not knowing what to do ! The weird thing is I dont get heat ! and the lines on the car build up solid amount of pressure hard enough you cant squeeze!
I really have no idea what is causeing this! I was just driving home one day and it all went to hell!
No smoke no coolant in oil !
YOu let it set and run it slowly burps out of car when it gets to 195 you rev it alittle and temp drops to 186 for 10 seconds and rises up and start to slowly burp outta tank !
I am praying that a tech god hopes on tonight!
So didnt mean to steal you thread !
Your car's not going to stay at 160 deg. Nor do you want it to, thats too cold. The temps you are at right now are fine. I have a 160 deg stat and I was driving around this weekend in 40 deg out side air temp and the coldest my car ran was 175 on my obd2 scan gauge. In the hot air (85-95 deg) my car will get to 210-215 after beating on it for awhile.
Sould all the little rows in radiator flow fluid ? if i look in there only 4 of them are !
If i let car set and idle it will not over heat!
another thing is with rad cap off and me reving it up it does down them splooshed back up when i let off throttle is that normal
I am really thinking the rad is full of **** and need new one flushed **** out it today and copper came out with little chuncks of white **** !
guys sorry bout typos i am not good spelling so just label me as a retard if you would like ! Kinda how **** goes for me anyway
Dont be so hard on your self your first post didn't sound like a over heat to me (186 deg). When I'm doing the steps above ^^^ my coolant temp will hit 240-250 when I shut it down and start the burping prosses.
