Low oil pressure problem with an lq4
Old Apr 30, 2010 | 07:49 AM
racin69z's Avatar
Default Low oil pressure problem with an lq4
I have done pretty thorough search, and I still can't find a fix for my problem.
I bought a stock lq4 from the salvage yard, did a cam swap, and put a carbed intake on it and put it in my truck.
When I start the truck, it takes about 30 seconds for it to get oil pressure. After that it will hold 30-35 psi at idle, but it does not go up with rpm. Once it finally gets pressure, it does not knock or rattle any at all.
Heres a list of what I have checked and replaced.
New pump o-ring. TWICE <I have read about the green and black ones, the one I bought at GM was red. I have also read about how hard these are to put in, mine slid in without much trouble. It did have to compress a little to fit in the pump but not much. Its definately not wedged in tight. I double checked with the GM dealer and he claims I have the right one.
New ported/shimmed late model pump.
New cam retainer plate/seal.
Check plug under timing cover for leaks.
New oil/filter. Tried both Mobile 5w30 and Valvoline 20w-50. Using Napa Gold filters both times.
Tried 2 different oil pressure gauges, the one I am using reads about 5psi more than the 2nd gauge.
Tried taking oil pressure reading from 2 different places.
So, I am at a loss. I would think if it was loose internal clearances, it would have lower oil pressure at idle and I would think it would still go up with rpm.
Does anyone have any ideas of what else I can check?
Thanks
Lynn
Old Apr 30, 2010 | 08:14 AM
jaber911's Avatar
Check it may be OilPickupTube and strainer block
from dust or
it Happened to me with my lq4
jr
Old Apr 30, 2010 | 08:20 AM
racin69z's Avatar
I forgot to add that I did check the pickup tube for blockage and leaks. I blew through it and then plugged one end and blew on it to check for cracks and leaks.
Thanks for the reply.
Lynn
Old May 1, 2010 | 06:26 AM
racin69z's Avatar
I found out the problem. I made a plate to block off the oil passages on the drivers side of the pan. I didn't know the oil had to go out one hole and back in the other.
Now it holds 60 psi cold and about 80 cold at about 3000 rpm.
Lyn
