Cam/Supercharger Question
Old Jan 13, 2004 | 01:39 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
blackcamaro, a 224/230//114 has a nice kick to it.
My lift is ~590/600. My ported 6.0 heads work at 600 lift.
Old Jan 13, 2004 | 02:42 PM
Black02SS's Avatar
I just switched from a 224 112 cam to a 228/230 114 FMS cam. I can tell you that there is really NO difference in sound through my true duals. Both cams sound almost identical.
Old Jan 13, 2004 | 03:29 PM
Inspector12's Avatar
TT-TECH Veteran
Yeah,
I wanted that too! And like I said there is a guy running the GM hot cam with his ATI.
But I don't think it would be fun to tune and it would not be opimal for a Supercharger? I don't know what else to do except to just go with a heads and cam set up. But I want more than that so I am doing the heads cam and blower. I hope it works ok!
Jeff
Old Jan 13, 2004 | 05:19 PM
Cal's Avatar
Cal
Originally Posted by BlackCamaroSS02
Damn i really wanted to have a cam with a good idle(by good i mean rough). isnt a 115 almost stock sounding? I mean i dont want anything over the edge but isnt there a blower cam out there that you would atleast be able to tell there is a aftermarket cam in there? basically just something with a nice rumble at idle.
Just because a cam has a 114 LSA does not mean it will sound stock. Idle quality is a result of intake/exhaust overlap; and overlap is a product of both LSA and duration. In other words, a 230 cam on 115 may have the same overlap and sound as a 224 on 112. Ramp rates also enter into this, so it's not that simple.
Old Jan 13, 2004 | 05:44 PM
LS1Tech Co-Founder
What Cal said...
Old Jan 14, 2004 | 12:54 AM
Spinmonster's Avatar
Andy at A&A in Cali. uses a 224/224 for his S/C applications. I was surprised at this but one of his customers just put down 660+rwhp with this single pattern and a stock displacement forged motor. I would give him a call first since he does these set-ups all the time. He states he uses it all the time by choice. He himself stated that it goes against common wisdom but it works.
Old Jan 14, 2004 | 07:30 AM
TT-TECH Veteran
Talked with Allen over at FMS yesterday and I think I am sold on the 224/230/.587/.591 114. I think it is the FM-7. Waiting on sale of my cam.
Thanks for all the imput and advice guys! I'll let you know how this works out!
Old Jan 14, 2004 | 08:15 AM
BlackCamaroSS02's Avatar
ok 2 questions
Question 1:will that cam put down good numbers N/A and pass emissions? If so i am sold.
Question 2: This question is about Heads. i am under the influence that a heads compression determins the power output and the heads cc rating determins the compression...correct me if i am wrong (example a 66cc head would put down more power then a 76cc head because the 66cc head has a higher compression) so my question is if i got AFR 76cc heads to drop the compression ratio to get ready for a S/C but didnt put the S/C on for a little would that N/A motor with a low compression ratio hurt performance and power alot...or no? cause i am thinking about getting AFR 76cc heads with that FMS cam (224/230/.587/.591 114) and have that installed and then start to save up for my S/C and the rest of the parts i need to complete the car. Will that N/A setup still put down good numbers? sorry about all the stupid questions
Thanks
~Tom
Old Jan 14, 2004 | 09:55 AM
LS1Tech Co-Founder
A 224/230//114 cam should dyno pretty well on motor.
A 224/224//114 wouldn't be a bad cam for a blower, is it the best, not according to cam folks but it's going in the right direction since it would not have a lot of overlap.
Old Jan 14, 2004 | 10:47 AM
TT-TECH Veteran
If you drop the CR for the supercharger you will lose some HP N/A but with the cam and the heads your car will still run good. I would think that with tunning it will run good enough for you to hold out for the S/C.
