rough idle
Old May 4, 2010 | 02:16 PM
Irocem99's Avatar
Default rough idle
My mechanic just put a new water pump in my 99 TA and a rear main seal.. Now for some reason it idles rough,no codes,no spark plug wires off..
Old May 4, 2010 | 04:26 PM
twitchtwice's Avatar
did he pull anything else off? maybe check for a vacuum leak?
Old May 4, 2010 | 04:38 PM
Paint_It_Black's Avatar
Any wires on the headers? Did he pull the headers off? Cracked a plug?
Old May 4, 2010 | 05:04 PM
Irocem99's Avatar
I don't have headers..I don't think he had to mess with the plug wires.. It vibrates the worst when you start taking off..
Old May 4, 2010 | 10:00 PM
lvbroham1's Avatar
could be the way he re-installed your tranny. did he replace the throw-out bearing?... Auto or M6?...
Old May 5, 2010 | 12:31 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would be looking at the tras as well. Do you have an A4 or M6?
Old May 5, 2010 | 03:21 AM
PowerShift408's Avatar
Check for vacuum leaks and loose sensor connections. Hell take it back to the mechanic and tell him to find the problem.
Old May 7, 2010 | 12:46 PM
Irocem99's Avatar
its an auto..there are no codes..its gotta be vacuum I'm thinking..
Old May 7, 2010 | 08:43 PM
No, it actually sounds like a trans problem like was mentioned before.
Old May 7, 2010 | 09:29 PM
crainholio's Avatar
You should take it back to your mechanic.
