Is .028 quench to tight?
Old May 11, 2010 | 04:55 AM
crainholio's Avatar
Originally Posted by monte383sbc
ok i checked my deck height again for the 50th time and iam coming up with .010-.011 out of the hole with the piston flat, and i came up with .023 rocked on one side and .024 rocked on the other side, soooo what is the minimum gasket i should go with .045 cometics, i have a set of .040s but that seems to tight of a quench, thanks for the help matt
If you don't plan on running high revs on a routine basis, I'd go with 0.045" gaskets. Otherwise, I'd go with 0.051" just for a bit of margin.
Old May 11, 2010 | 09:44 AM
monte383sbc's Avatar
iam probly gunna rev it high, probly to a tad under 7k maybe 67 or 68, i will see when iam on the dyno how my ms3 cam powerband is.
Old May 11, 2010 | 05:33 PM
can i get away with .045''s with my deck height at .010''-.011'' and ill be reving the motor pretty good or just go with the .051''?
Old May 11, 2010 | 05:59 PM
Tony Mamo @ AFR's Avatar
Flow Wizard
Originally Posted by Bad Notch
Damn, I'd trade you my new .045 Cometics for your .040 if your interested.
There's your answer right there!!
.045 leaves you with the perfect quench distamce IMO....as long as your pistons dont have excessive piston to wall clearance (more clearance means more rock which means more quench distance required).
I usually shoot for .030 - .035.....but I also know I have minimal piston rock in all my builds.
Your deal at .033 with the .045 gasket should be fine. I dont recommend the .040 scenario for you.
-Tony
Old May 11, 2010 | 08:44 PM
87silverbullet's Avatar
-Tony
There you go, the master has spoke. Take the blue pill (the .045 gasket).
Old May 11, 2010 | 11:12 PM
ssinister550's Avatar
you need at least .035 and no more than .055
Old May 17, 2010 | 04:22 PM
-Tony
well my piston rock is .023''-.024'' on each side of the piston, is that to much rock with a .033 ''quench? if so iam just gunna by the cometic .051's
Old May 17, 2010 | 07:18 PM
Flow Wizard
Thats not excessive....probably close to .005 piston to wall if I had to guess.
Go with the .045 is my suggestion....but I wouldn't lose sleep over either as long as you maintain the same static CR.
(Meaning going with the thicker gasket and not compensating with a slightly smaller chamber would cost you some power due to less quench and less static CR).
-Tony
Old May 18, 2010 | 07:33 PM
hey thanks allot tony, just wondering do u know steve ramage from rs competition racing engines?
Old May 18, 2010 | 09:36 PM
stinkybutt's Avatar
Default don't forget about the piston rocking
Deck height and quench are important. BUT you also need to understand that piston to bore clearance and skirt length can make a big diference in how much the piston can rock in the bore. If I am thinking right on your bore size it takes .006" for 1cc of volume. So even with .012" extra deck clearance you are only adding 2cc or so of volume. I think the extra room is worth more than the min gain in hp.
Just a few thoughts out loud.
When we tune a car on the dyno we always take a couple degrees back in timing so the customer has a safe tune and doesn't hurt his engine because of a tank of crappy fuel. Set the tune on kill and no cusion for driver(customer) brain fart.
Aleck
Old May 20, 2010 | 07:27 PM
Flow Wizard
Steve from Long Island?
He used to have his shop a few streets down from Shafiroffs older place in W. Babylon....
Ive helped him a few times here and there at AFR but I dont speak with him on a regular basis at all.
Not even sure if he's still in Long Island.
-Tony
Old May 22, 2010 | 08:20 PM
  #32
-Tony
ya thats him lol, i worked for him for about 2 years a speed shop in colts neck new jersey but hes screwing up dont really wana get in to it but i was just wounding if you knew him, which i was pretty sure u did lol, ya he just got a new shop back on the island but i havent bin there yet........
Old May 23, 2010 | 05:30 AM
  #33
Nitroused383's Avatar
I'd run the .051" $28 GM MLS gaskets from scoggin dickey and call it a day. There is nothing wrong with .040" quench. The extra safety is worth the piece of mind. What do I know though my budget non ported / non optimal quench junk made more toque under 4000 rpm than most high dollar setups. If you're worried about the lower compression go spend $50 at an automotive machine shop and have them mill the heads.
Old May 23, 2010 | 08:08 PM
  #34
will i be safe with the gm mls gaskets if i hit her with a 200 shot?
Old May 23, 2010 | 08:53 PM
  #35
Ws6kid.'s Avatar
i finally got my mahle -4cc pistons in with my stock crank and ls2 rods, now i checked my deck height and i came up with .011-.012 deck height will i have enough room with .040 cometic head gaskets which would be .028-.029 quench? also this is gunna be my daily driver with 11:1 compression and running on 93 octane. any help apprciated thanks matt
im sure theres a thicker head gasket out there right?
Old May 23, 2010 | 09:18 PM
  #36
i did more research and i just bought gm mls gasket they should be fine, my cometic .045s are forsale now b/o
Old May 23, 2010 | 10:47 PM
  #37
People have less issues with the GM MLS gaskets than they do the cometics. The forced induction guys have made a lot of power with both gaskets.
Old May 24, 2010 | 01:31 PM
  #38
Randy WS6's Avatar
Ive been using the GM-MLS head gaskets for years and never had any problem with them on my stroker and with a 300shot on top of that, But i do use copper spray on them.
Old May 25, 2010 | 12:18 PM
  #39
LilJayV10's Avatar
Is there a average how much stock pistons stick out of the block on a stock LS1? The heads I have now cc'd at 64. After I measure PTV I will have them milled some to get closer to 62. I am wanting around 11.5:1, that's with a .51 MLS gasket.
I think Tony touched on this a few posts up but I want to make sure. For me to get around .40 quench the stock piston is going to have to be up .11 right? Should I run a thinner head gasket that would up my quench and compression or just have the heads milled to up the compression.
I am not meaning to high jack your thread. Since you figured out what you are going to do I thought it made more since to post in here instead of starting a new thread almost the same.
Old May 25, 2010 | 02:27 PM
  #40
They stick up .006-.008". 62cc chambers with the GM .051" gasket will give 11:1 compression. If you are paying to have the heads milled have them milled to the spec you want the first time so you do not have to waste money on cometic gaskets. Every .0065" milled off the head will = 1cc. A 59cc chamber will get you 11.42:1 with a GM MLS gasket. A .040" cometic will get you 11.47:1 with a 61 cc chamber. If you are running anything over a mid 220's duration cam you will need to notch your pistons for proper piston to valve clearance.
