What can I do to this bare block?
Old May 5, 2010 | 05:10 PM
Wnts2Go10O's Avatar
Default What can I do to this bare block?
what can i do to this 2003 6.0l bare block:
de-bur?
oil restrictors?
painting?
etc?
also, if anyone has a trick to get the main caps loose, itd be appreciated.
Old May 5, 2010 | 06:39 PM
KCS's Avatar
KCS
Moderator
de-bur?
oil restrictors?
painting?
etc?
Deburr it, clean it, build it.
Don't do oil restrictors.
After you've removed the bolts (including the side bolts), you can usually just pull them out by hand, just wiggle from to rear. If not, use two long prybars at the ends of the caps.
Old May 5, 2010 | 08:24 PM
Wnts2Go10O's Avatar
got em out. used c-clamps under the notches and used a 1x1 on either side to pry strait up an out.
i was wondering if any of the sbc tricks would work. like screening and all tht
