Dyno queens inside
Old Jan 10, 2004 | 06:31 PM
Black02SS's Avatar
I wouldn't consider myself a dyno queen either, but after seeing what I dyno'd and how it ran at the track I was really impressed. Raceweight of my car is roughly 3650. TEA stg. 2 5.7L heads milled .030, 12bolt 4.11's, Macs, all bolt ons except FTRA and a asp pulley. Best time at the track was a 12.0 @ 116 mph 1.78 60'. If I could have had another run in I might have been able to hit high 11's. DA was around +800 that day. 411/378
Old Jan 10, 2004 | 09:07 PM
Chris81's Avatar
Originally Posted by offaxis
Whendid you dyno ? Anytime you dyno ona day cooler than 77 deg and with a bar higher than 29.92 + range you will have a higher actual dyno# . I know you guys in texas get good DA days .
I dynoed the Camaro on Sept. 27th (best pull at about 10:30 pm, I don't have the dyno sheet on me) and the conditions were:
Temp: 70
Dewpoint: 53
Humidity: 51
Barometer: 30.12
Actual alt: 3000 ft
Density alt: 4358 ft
I dynoed the Trans Am on Dec. 13th (best pull at 10:10 pm) and the conditons were:
Temp: 40
Dewpoint: 11
Humidity: 31
Barometer: 30.06
Actual alt: 3000 ft
Density alt: 2323 ft
So, since the temps are under 77 and the barometer over 29.92 I should have higher STD numbers than SAE??
Could there be a problem with the way the dyno is being operated?
Any help would be great, i'm very curious about this..
Thanks, Chris
Old Jan 10, 2004 | 09:22 PM
Casper9T9's Avatar
Chris I think that it would be true at sea level, but not at our elevation.
Old Jan 10, 2004 | 10:06 PM
Kurtomac's Avatar
Originally Posted by 10secondZ
Hey Kurt, What's up man it's Carter,
Glad to see those numbers and glad to see you are pleased with the head's.Did the scratch on the exhaust seal up good? Anyway's man that is very impressive numbers for that cam through the 12 bolt...now get that sucker to the track Later,
Carter
went to the track today went 11.60 at 118mph on a 1.73 60ft not too shabby
Old Jan 11, 2004 | 01:57 AM
Black02SS's Avatar
Question
Raceweight, track conditions, weather, shortbelt, ect???
Old Jan 11, 2004 | 02:00 AM
10secondZ's Avatar
Sweet! nice trap speed as well..congrats man.
Carter
Old Jan 11, 2004 | 12:08 PM
Kurtomac's Avatar
my car is a pig.....1/4 tank of gas jack and spare in the car weather was about 45 degrees and track hooked up good.....car as i drive it on the street no tricks....btw i weigh 180 so you do the math on the weight if ya want along with heavy *** ws6 wheels and 16" ET streets on the back 1.73 60ft....on the weight if anybody wants to figure it up dont forget the loaded moser i got i would expect the race weight to be up there at 3800 or so
