Casting #'s info please....(cylinder heads)
Old Jan 11, 2004 | 02:28 AM
WiseGuyZ's Avatar
From: BOSTON IS MY HOME, BUT NOW, IAM A PERMINENT VISITER HERE IN TAMPA.
Default Casting #'s info please....(cylinder heads)
What is the casting # on the LQ9 6.0L Head. If Im not mistaken they should be labled on the passengers side cyl head.
Also is 243 the casting # on the LS6 Heads???
Old Jan 11, 2004 | 04:39 AM
johnny p's Avatar
LS6 = 243 Casting # located on the lower right of the Passenger side , And to keep this simple as possible LQ9 6.0L Head is casting # 317 .
( A LQ9 Has D Shaped exhaustport and an LQ4 has an O exhaustport )
Old Jan 11, 2004 | 06:53 AM
2000Firehawk's Avatar
No no no...
LQ4 & LQ9 heads , both are the same...
LQ4 = dished pistons = 9.5 CR
LQ9 = flattop pistons = 10.1 CR
Same ports, same everything...
A truck that has the LQ9 engine may have [317] or [035] heads on it...
Dave
Old Jan 11, 2004 | 03:29 PM
johnny p's Avatar
Originally Posted by 2000Firehawk
No no no...
Dave
What the hell are You saying no about ? Casting #'s are right 317 or 035 , But aren't the Exhaustports different like I said ?
Old Jan 11, 2004 | 06:30 PM
Jason99T/A's Avatar
I can shift faster than you.
The heads found on an LQ4 and an LQ9 are identical. Both share the same intake and exhaust ports, as well as the combustion chamber shape/volume.
