MTI r1 combo question
Old May 17, 2010 | 11:17 PM
w3s1c0a5t's Avatar
Default MTI r1 combo question
I have the r1 grind (232/236 57x/57x 114) With ported and valve job 98 heads with an ls6 intake on stock bottom end street strip car.
Curious if i should install the cam straight up. Also should i have the heads milled at all? Not interested in flycutting so keep that in mind.
Thanks in advance guys.
I have a 4000 stall 4.10 about 3100 pounds but still stock rod bolts so will be shifting at 64-6500.
Old May 17, 2010 | 11:20 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would dot to dot that sucker and button it up. That cam is a tad on the dated side IMO. Only way we are going to be able to tell you is.....well, we accurately can't. You will have to measure PTV and then take the heads in with that measurement and have them take off some material and still leave you with a tolerable clearance to insure if valve float were to occur, you won't start shoving holes through the combustion chambers.
Old May 17, 2010 | 11:30 PM
w3s1c0a5t's Avatar
As far as the milling i wasent sure if i could take a little off and still be sure.
Thanks for the reply
Old May 17, 2010 | 11:47 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would think you could probably be okay with a cleanup mill, but that is all I want to tell you without having some measurements to look at.
Old May 18, 2010 | 10:52 AM
A_VAS's Avatar
I'd suggest installing that cam at 110* ICL (+4) or even a 108 (+6).
This assumes there is no advance ground in...should tell you on the cam card.
Old May 18, 2010 | 12:01 PM
w3s1c0a5t's Avatar
Why sir?
I was thinking that with the 114 it would want to pull past what im going to shift at.
Old May 18, 2010 | 03:10 PM
A_VAS's Avatar
that's a sizeable cam for a LS1, I feel the valve events look better at at 110 ICL. You'll still pull up high with the duration that it has.
Old May 18, 2010 | 03:50 PM
w3s1c0a5t's Avatar
What would the powerband look like installed on that icl
Old May 18, 2010 | 06:23 PM
SOMbitch's Avatar
I would guess on a 110 ICL it would peak around 6300 and carry past 6600 a bit with a FAST IM. That is about what my similiar cam does on a 111.....
edit: Actually my ICL 109....
Old May 19, 2010 | 12:15 PM
w3s1c0a5t's Avatar
Thats prolly what i need to do. I dont want to shift past what im comfortable with the 98 rod bolts.
Old May 19, 2010 | 10:46 PM
w3s1c0a5t's Avatar
So how should I physically install it? With the dot 2 teeth advanced?
Old Jun 19, 2010 | 10:56 PM
w3s1c0a5t's Avatar
Bump About to actually toss this in.
With a 6500 shift point im thinking a 108 ICL will bring the powerband
Running a pt4000 3.42 ls6 intake
Old Jun 20, 2010 | 07:39 AM
crainholio's Avatar
No don't do that. Dot to dot. Use a straight-edge through the centerline of the cam and crank to verify the dots are aligned, and not off by a tooth.
Old Jun 20, 2010 | 10:47 AM
w3s1c0a5t's Avatar
Looking for actual advice.
Old Jun 20, 2010 | 01:16 PM
crainholio's Avatar
OK, you're right, go ahead and install it 2 teeth advanced. Lots of guys do it. I was just part of the secret conspiracy to keep you from making major power and you caught me.
Old Jun 20, 2010 | 08:46 PM
w3s1c0a5t's Avatar
Was actually just thinking you were ignorant.
Old Jun 20, 2010 | 10:17 PM
crainholio's Avatar
You pretty much have to be, in order to give advice on the internet. No sane, rational person would do it.
Old Jun 20, 2010 | 10:29 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
BWAHAHAHAHAHAAAA!
