Engine stutter at high r's and at wot
Old May 19, 2010 | 08:05 AM
velox65's Avatar
Default Engine stutter at high r's and at wot
Got a weird problem, car runs great with general driving, but when I lay into her she runs good for a bit then baam it seems like a severe misfire (bad coil or fuel?)but no codes are thrown, only codes is the tps. It only stutters at the high end and I can let off and do it again and sometimes it won't miss a beat. I've done about everything I can think of and I'm stumped
Old May 19, 2010 | 08:39 AM
DaveX's Avatar
Maybe it's tagging the rev limiter? If it's an A4 it will typically shift slightly after the set point as it takes the trans a few milliseconds to actually shift. Mine does this once in a while, particularly if it's spinning the tires when it shifts because the rpm's are building faster than they would be if it wasn't spinning.
Old May 19, 2010 | 08:50 AM
velox65's Avatar
Don't think so, it does it around 5500 my limiter is 6700 and it's a little harsher than bumping the limiter
Old May 19, 2010 | 12:59 PM
PewterLS-1poweredSS's Avatar
Could be your valve springs. Mine had a stutter that started at 5000rpm and lasted till about 5500 then pulled fine until the rev limiter. After I changed the springs out it was gone. Also the motor will make a funny sound when the stutter is happening.
Old May 19, 2010 | 04:01 PM
velox65's Avatar
you have weak springs and switch to the same type or upgrade?
Old May 20, 2010 | 03:07 PM
velox65's Avatar
Bump..
Old May 21, 2010 | 10:36 AM
I upgraded to yellow ls6 springs. Next time I would definatly go with something stronger, the problem is starting to come back.
Old May 22, 2010 | 04:29 AM
Soul TKR's Avatar
Sounds like your getting valve float... what's the mileage on those springs? I agree... sounds like upgrade time.
Old May 22, 2010 | 10:05 AM
velox65's Avatar
Yellow ls6 springs I was told low mileage, it also seems to do it at lower r's like when it's being lugged but rarely
