Power Gains
Old May 20, 2010 | 07:40 PM
Formulals187's Avatar
Default Power Gains
What sort of power gains have people gotten with a TSP Torquer V2?
Old May 20, 2010 | 07:58 PM
David Q's Avatar
I didn't dyno mine before the install, but afterwards it made about 100-120 more rwhp than factory advertised with torquer 2 and stg 2.5 5.3 heads. It ran a 13.30 stock and 11.50 after install. It pulls hard on the street, sounds good through free flowing exhaust, and is a good DD cam with a good tune.
Old May 21, 2010 | 04:13 PM
What are good cams to build good torque and mid range power for an A4 to get around the 400 marks? Or should I custom grind a cam?
Old May 21, 2010 | 04:27 PM
garygnu's Avatar
get a custom ,not much more than a off the self cam.I feel the ed curtis street sweeper or the TR224 cam mite do what you want.
Old May 23, 2010 | 09:18 PM
What specs should I custom grind a cam?
Old May 24, 2010 | 06:51 PM
With these specs ( 234/230 602/598 on a 112 LSA) would this cam make good horsepower and torque?
Old May 24, 2010 | 07:19 PM
supersick99z's Avatar
If you custom grind a cam most places offer a sheet for you to fill out exactly what's done to your car so they know how to spec the cam
Old May 25, 2010 | 06:19 PM
projectX's Avatar
I want a cam in the middle. Not too mild nor wild. I don't plan on heads any time soon so something that will make good horsepower alone without too rough of an idle. Any suggestions? I have an 01 TA A4 basic bolt on.
Old May 25, 2010 | 09:08 PM
garygnu's Avatar
a TSP 228 camkit or a tr224.
Old May 25, 2010 | 10:06 PM
Quik Sand's Avatar
Think I made 347 with midlengths, lid, ls6 intake, and cutout. Currently make 401 with those same mods and v2.
Old May 26, 2010 | 01:05 AM
SOMbitch's Avatar
About 50 with bolt ons......
Old May 26, 2010 | 01:10 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
As much as I wish a reverse split was ideal these days I would suggest that you may want to read the cam guide and then decide what you want to do. Call TSP or EPS and have them spec a cam per your specific application. Nothing wrong with just an off-the-shelf grind though. Sometimes. But you seem like you are nearly clueless as for what you need.
The TR224 or the TSP228r are both tried and true cams. Generally you will be down on torque if you reach out to these 240's duration'd cams though. Stick to the low to mid 230's and not to low of an LSA.
ALSO. I am guessing you are an A4. Are you already stalled for a cam or you still running the stock verter?
Old May 26, 2010 | 06:26 PM
projectX's Avatar
alright
Old May 26, 2010 | 06:31 PM
projectX's Avatar
Also do I have to get a stall if I get a cam? I don't want my tranny to get burned out. I have 115k on it already. Thanks!
Old May 27, 2010 | 12:01 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you want to get anything out of that cam, then I would look at getting a converter.
Old May 27, 2010 | 01:55 PM
projectX's Avatar
What is a good brand? Also, I use it mainly for DD so how high RPM should I go? 2800 stall
Old May 31, 2010 | 07:49 PM
Circle D's are good converters, get atleast a 3000 stall
Old Jun 1, 2010 | 10:02 PM
thislswon's Avatar
I have similiar mods as this guy and i am making 420/390. Car has great street manners and pulls very hard. Love the combo! No track times yet
Old Jun 1, 2010 | 10:38 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah, Circle D makes a good converter.
