colder plugs question
Old May 24, 2010 | 05:44 PM
02fbody35th's Avatar
Default colder plugs question
i was wondering if running a colder plug in a stock ls1 would help with detonation. my car has been pinging at high rpms on hot days. so i was thinking if i put a colder plug in i can get the temps down a bit to prevent detonation. has anyone done this. i know i could risk fouling but i would do anything to prevent the horrible ping.
Old May 24, 2010 | 05:46 PM
sidewayz28's Avatar
maybe tune it...?
Old May 25, 2010 | 04:32 AM
vettenuts's Avatar
Try doing a Seafoam treatment first, then swap the plugs. Carbon build-up can cause the pinging (if you are stock) or high coolant temps.
Old May 25, 2010 | 06:00 AM
lordrazo's Avatar
i would ee with vettenuts problem is when its hot and high rpm are ideal times for detonation with gas now being so thin too some stations i notice you can get away with it but others way too thin here in florida racetrac omg sooo thin
Old May 25, 2010 | 11:12 AM
bjamick's Avatar
Put a Tr6 plug in and see if it fixes it. I've got a BR7Ef in mine right now and I can feel I've lost some na power by going 2 steps colder. It is great for the nitrous though.
Old May 25, 2010 | 02:50 PM
jmm98LS1's Avatar
It's just in your head, going colder on the plugs will not lose any appreciable power. On motor I ran the same times/mph at the track with TR6 and ngk -8 plugs, back to back runs within 2 hundredths and .3 mph.
Old May 26, 2010 | 05:51 AM
bjamick's Avatar
Maybe I'm getting used to it, well guess I need to throw on those heads I've got.
Old May 26, 2010 | 01:35 PM
samb0ness's Avatar
I just finished a cam install in my car last week. It was backfiring/predetinating like crazy. Under WOT, it would studder a lot. I had the NGK TR55 Iridium XI (i think) plugs in. Gomer suggested they were too hot, and that I throw in the regular TR55 copper cores, and it's been doing fantastic since the change!
Old May 27, 2010 | 08:11 AM
bjamick's Avatar
Hey aren't you the one I helped out a lil bit with the cam install?
