car wont start after rebuild
I got it all installed in the car and it will not start. It will turn over no problem.
I checked all the plugs, coil packs, fuel pressure, grounds, everything but compression.
When I first started it, it fired right up, idled to 1000 rpms, went up to 1400 rpms and then died. And now it will not start up. Every once and awhile, it will pop like it is trying to start.
The only thing I did not do is soak the lifters. I read on here and my books, soak the lifters, dont need to soak the lifters.
After I could not get it started again, I took the head covers off to check the rockers and springs. All the rockers were tight but I could move the rockers freely on the intake valves. back and fourth from the push rod the the valve.
I even took the fuse's out for the injectors and pulled the plugs and turned it over for about a minute to build oil pressure. nothing
I dont know what else to do except to take the heads off and soak the lifters.
The codes that it is throwing, pulled with HP turners.
[PCM] P1637 - Generator L-Terminal Circuit (Pending) (Old) (History) (Current) (Immature)
[Brake] C0237 - Rear Wheel Speed Signal Erratic (History)
[Brake] U1000 - Class 2 Communication Malfunction (History)
[Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Restraints] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
[HUD] U1000 - Class 2 Communication Malfunction (History) (Immature)
I am still thinking it can be collapsed lifters.
I dont know what else to do.
Fuel pressure is good. You checked the coil connectors and the grounds. Did you check each bank for spark at the plugs?
