car wont start after rebuild
consider:
pull the valve covers and make sure the valves are moving. do a static compression check. Is the cam dot to dot?
do a spark check, throw a plug on the exhaust and check it.
pull a plug and see if they smell like fuel.
fuel pressure??
make sure the batter cables are tight on the battery.
fuel pressure??
The bigger hole helps more air come in at start up. It makes a difference, I don't know if its enough difference to take it from completely not starting to starting. Maybe worth a shot.
I see no mention of having the PCM recalibrated for upgraded mill in the O.P. and it sounds exactly like a "One and Done" type of situation.
Thats where your new motor will fire up exactly once and the PCM can't keep up with the number of parameter changes needed that the engine dies and won't start again.
I'd look into a Mail-Order-Tune for the time-being and eventually a Dyno-Tune to safely optimize the upgrades.
Keep this thread updated. I'd like to know what you find. Good luck, man.
#32
I'm with these guys.
#33
I assume you have HP tuners since you mentioned the codes. Have you tryed loging any info such as injectors while you are cranking it over. Maybe you could try and disable the vats if the injectors are not firing. I would also check the plugs and see if for whatever reason they are wet. Is there a possibility of a loose or broken pin on the vcm where the harness plugs in?
I dont know if you changed the crank or not, but are you sure you have the right reluctor wheel. Are you sure the cam is installed correctly?
Im sure you will figure it out sooner or later.
Good Luck
Duane Troike
Good Luck
Duane Troike
#34
I don't have the answer to it, but it seems logical that with the battery disconnected (both Negative and Positive Terminals) the PCM should reset. It would then attempt to re-learn to make the car idle/run properly.
If this is the case, the engine should fire and run for a short time before dying again.
Obviously this isn't the fix to the problem, but at least you will have pinpointed it.
I'd say its worth giving a it a try.
#35
CKP has been eliminated, see these posts above:
