Future mods for 2000 Trans am
Old Jun 2, 2010 | 04:43 PM
vetteboy99's Avatar
Default Future mods for 2000 Trans am
Transmission/suspension:
4.56 Gears
98-02 LS1 Ram HDX Performance Clutch Set
98-02 LS1 Fidanza Aluminum Flywheel
93-02 Koni Camaro/Firebird Sport Shocks(Fronts) Single Adj.
93-02 Koni Camaro/Firebird Sport Shocks(Rears) Single Adj.
98-02 LS1 Eibach ProKit Performance Springs
Engine/Exhaust
98-02 LS1 Hypertech 180* Thermostat
98-02 LS1 BBK Full Length Header System & OFY (Chrome)
98-02 LS1 MSD Blaster Coil Kit (Set of 8)
98-02 LS1 MSD 8.5mm Super Conductor Wire Set
98-02 Fast Toys LS1 Black 104mm LS1 High Flow Air Lid
FAST LSXR Intake Manifold (102mm Inlet) Manifold For LS1/LS2/LS6
98-02 LS1 Nick Williams 102mm Throttle Body
98-02 LS1 Fbody Fast Toys Performance TSP 100mm MAF Sensor
98-02 Comp Cams Xtreme XE-R 232/234
Manley Perf. Valve Springs Single Spring w/o Damper Max Lift .57
Dyno Tune. Want To know if there is prolly anything better or these are good enough parts that will get me to over 400rwhp without heads
Old Jun 2, 2010 | 04:52 PM
samb0ness's Avatar
i got over 400rwhp in my '01 ss with lid, exhaust, and 230/232 comp cam...so with that list of stuff, i'm sure you should bust through the 400 mark
Old Jun 2, 2010 | 04:53 PM
Vindicated346's Avatar
I would take out the MSD blaster coils, and try to find the 6.0 truck coils, been proven and you can probably find them cheaper, and its just a personal thing but i wouldnt go with chrome headers..i would try stainless, but good combo so far
Old Jun 2, 2010 | 05:56 PM
SOMbitch's Avatar
I hated my bumpstop riding Eibachs on my old LT1 car. They sucked so bad I bought a set of stockers and put back on...IMO literallly almost anything else is better and I have ridden/driven several brands....
X2 on the MSD coils
Big TB's like that won't gain you anythig unless you are BIG cubes and can be a PIA to tune.... same with that MAF..... both overkill......
Old Jun 2, 2010 | 06:01 PM
King Nothing's Avatar
i agree with these guys. if need be OP call ron at vengeance and talk to him about the intake and tb more in depth
Old Jun 3, 2010 | 04:13 AM
vetteboy99's Avatar
Ok, So what kind of intake manifold, tb, and MAF should I get. LS6 Intake, ported TB, and What kinda MAF Sounds better?
Old Jun 3, 2010 | 04:33 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Leave the stock MAF on there and don't mess with it.
Old Jun 3, 2010 | 04:53 AM
vetteboy99's Avatar
I guess I will be doing that
Old Jun 3, 2010 | 04:55 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, really if you wanted to you could pick up a stock Z06 MAF or the Delphi one. They are 85mm. But I would definitely not port/polish/de-screen it.
Old Jun 3, 2010 | 04:57 AM
vetteboy99's Avatar
Yea I was just about to ask If i should get a z06 one
Old Jun 3, 2010 | 05:09 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Ron @ Vengeance should be able to set you up with a max effort ported 102 FAST and matching TB. I believe that was what he was refering to with the call Vengeance portion.
Old Jun 3, 2010 | 06:24 AM
vetteboy99's Avatar
i pm'd him. What about the other mods?
Old Jun 3, 2010 | 10:31 AM
vetteboy99's Avatar
And change the cam to a torquer v3
Old Jun 3, 2010 | 10:40 AM
Damian's Avatar
LSX Mechanic
With those parts listed, you're going to spend a whole bunch of money to get less than stellar results. Lemme break it down for you..
-You do not want to put 4:56 gears in a 10 bolt. You'll shatter them the first time the tires stick. Do not go any higher than a 4:10.
-Ram clutches are decent. Not a bad choice there.
-Unless you can shift lightening fast, do not run a Fidanza flywheel. They're too light and lose a lot of momentum during shifts. I've seen this flywheel slow down a LOT of cars. Lighter does not always mean better. Get a billet steel.
-Why the Koni's? Put a set of Bilstein revalved HD shocks on there with some Eibach springs. It'll handle nearly the exact same, for 1/4 the cost.
-For $100 more, you can get a much better header selection from Pacesetter, opposed to the BBK's. The BBK's are ok, but they have garbage ball flanges and a 2.5 Ypipe.
-MSD coils are junk and a waste of money. I've seen several of them fail. Stock GM coils are good to very high HP levels. Another waste of money.
-MSD wires are junk. Run a GM LS2 wire. Better than MSD, half the cost.
-A fast 102mm is an overkill for a cam only car. Cam only LS1's only need a 90mm at best, for cost effective gains.
-The 232/234 cam is not a very good grind. Never seen one make power that was impressive. Drop down into the 228/232 or 230/232 range on a 112-113+4. You'll get better results and more TQ.
-Comp 918 springs work just fine with an XE-R lobe if set up properly. No need to buy a heavy spring that's going to cost you power unless you're running .600-.620 lift with a square lobe.
In closing, stop reading the parts catalogs and making your decisions off of vendors claims. Do some research. You can achieve your goals for a lot less money. I do it every day.
Old Jun 3, 2010 | 11:13 AM
vetteboy99's Avatar
Thanks Man, I posted this then Started doin alot of research. And I changed my WHOLE mod list and you just made me change it a little more. Lol. But I have also been lookin for ls6 shortblocks to incase I find one cheap.
Old Jun 3, 2010 | 11:33 AM
vetteboy99's Avatar
and for 1200 I can get a forged 408 Pistons and crank kit. Is it a good Deal?
Old Jun 3, 2010 | 12:07 PM
you can't buy them brand new. gm only sells the longblock for a 04 ZO6. you can buy them used but if your like me you wont do that lol i'm just goin to buy a LS6 longblock then sell the brand new heads and cam to make some money back, plus i have some damn good heads and a cam anyway lol
yes and no. lean more towards the no part cause unless your an engine builder your still goin to have to buy a block and have it machined etc etc etc so your better off goin through a good place to get a engine already built. and yeah talk with ron at vengeance, give him a call if pm doesn't get answered. personally i'd suggest a ported 102 with a 92tb, i'm no genius but even i know you wont need a 102 tb
