Question: A 4.25" Stroke on LS Block (Standard Deck Hight)... It is possible
Old 06-03-2010, 02:23 PM
LS6
LS6's Avatar
Default Question: A 4.25" Stroke on LS Block (Standard Deck Hight)... It is possible
Has any one done a 4.25" stroke be installed on a LS block (9.24" deck hight) regardless of streetability or oil consumption issue???
I read a book stating that a 4.25" stroke can be with some trimming requirement...
Old 06-03-2010, 02:47 PM
bww3588's Avatar
that would require a longer than normal rod to keep it from rocking at the bottom of the bore. oil consumption issues aside, id say it would work with quite a bit of clearencing.
Old 06-03-2010, 02:59 PM
LS6
LS6's Avatar
Thus a 6.125" connecting Rod wouldn't work fine with 4.25" stroke...
Old 06-03-2010, 03:04 PM
bww3588's Avatar
its hard to say. you would have to measure the usable length of the cylinder and keep the wrist pin above that point. thats why i say a 6.200 rod would probably be better.
Old 06-03-2010, 07:26 PM
brian_rs/ss's Avatar
why not a slightly smaller stroke? why does it have to be a 4.25"?
Old 06-04-2010, 05:19 AM
LS6
LS6's Avatar
cause I need a trmendus tourqe where this engine will be uses in dirt sand cliff (hight almost 100 meter with an agnle of 30 degree) race.
Old 06-04-2010, 08:26 AM
trans_am7935's Avatar
just supercharge it, there is all the torque u need and no problems of burning up all your oil. much more reliable power too
Quick Reply: Question: A 4.25" Stroke on LS Block (Standard Deck Hight)... It is possible
