Lifter preload?
Old Jun 3, 2010 | 07:21 PM
monte383sbc's Avatar
Default Lifter preload?
ok i just finshed building my forged 347 and now i just installed my scorpion 1.7rr's and iam coming up with 1 3/4 or a turn to 22 ft lbs. does that see like to much lifter preload? or do i need shorter push rods?
Old Jun 3, 2010 | 07:45 PM
Darkman's Avatar
1 3/4 turns is at the maximum of the range, 1 1/4 being minimum. This assumes OEM lifters (LS1/LS7).
Old Jun 3, 2010 | 07:58 PM
i got comp r lifters
Old Jun 3, 2010 | 08:27 PM
Darkman's Avatar
At 1 3/4 turns you have .082 preload.
Do you know your target preload?
Comp recommends adjustable rockers for those lifters presumably because their required preload range (minimum - maximum) is narrow.
Added:
Additional research indicates that Comp calls for a preload of 0.002 to 0.0004 inch. Some folks report satisfactory results using 0.010 inch and others have run preload based 3/4 turn. Thus, these lifters are designed to use adjustable rockers, but in any event the current 1 3/4 turns of preload is too high and you need 0.075 inch shorter push rod.
