TR6 spark plug gap
Old Jun 4, 2010 | 04:11 PM
Phil'sC5vette's Avatar
Default TR6 spark plug gap
what is the suggested spark plug range on the TR6 plugs, for the modifications listed in my sig?
Old Jun 4, 2010 | 05:10 PM
Darkman's Avatar
Spark Plug Part No. Gap
V-Power TR6 4177 .054
G-Power TR6GP 5141 .054
Laser Platinum PTR5F-11 .054
OE Laser Iridium ITR6F13 .054
Iridium IX TR6IX 3689 .054
Old Jun 5, 2010 | 12:11 AM
more inmput in a heads and cam car with 11:1 compression
Old Jun 5, 2010 | 04:03 AM
02*C5's Avatar
y are u running a tr6 if your not running n2o run a tr55. if your running the bottle then run a tr6 and even then only to a 150 shot after that a br6ef is what you'll need. if its straight n/a tr55 is what you need period.
Old Jun 5, 2010 | 09:13 AM
vettenuts's Avatar
NGK recommends one heat range reduction for every 100 hp added. I have the setup in my signature and am running TR6 plugs with the gap as provided from the box. If you want a larger gap, the 2nd number (TR55 for example) provides the larger gap. In other words the only difference between TR5 and TR55 is the provided gap.
I am running them straight from the box and it runs great. I have had them out several times and they are clean and appear to be functioning properly.
Old Jun 5, 2010 | 12:56 PM
chrs1313's Avatar
11.9:1 here running the tr6 gapped at .035...also tick has done back to back dyno tests and this gap with the same plug gave the highest hp...
a straight tr55 is not cold enough when you start upping the compression...
485rwhp though a locked a4 here...
Old Jun 5, 2010 | 02:18 PM
Thanks guys.
I just need the gap size, not plug suggestions
Old Jun 5, 2010 | 05:53 PM
vettenuts's Avatar
Guess my answer was a little confusing because I was also trying to address the TR55 suggestion. I am running TR6 with the gap provided by NGK, which is 0.040" out of the box.
 Michael S. Palmer
Old Jun 5, 2010 | 06:19 PM
Darkman's Avatar
http://www.ngk.com/results_app.asp?AAIA=1432483
http://www.ngk.com/results_app.asp?AAIA=1432727
http://www.ngk.com/results_app.asp?AAIA=1433649
Old Jun 5, 2010 | 09:28 PM
looks like im .045
Old Jun 5, 2010 | 09:59 PM
chrs1313's Avatar
that is good an all but I checked all of mine and they were are around .040 out of the box tr6...I tightened them up to .035...
