new cam, small problem
Old Jun 8, 2010 | 10:15 AM
Ethan[ws6]'s Avatar
Default new cam, small problem
Just installed my cam/heads and when I went to drive the car it started over heating. Bled the air out of the cooling system and was filling the radiator while the car was running (so I could keep filling it as the water was being pulled through) and out of no where I see smoke and hear water hitting my passenger header. Sure enough I look under the car and there is water pouring onto the end of the header. No water is being spilled from the engine inside the engine bay as far as I can see so I'm really confused. Any Ideas?
Old Jun 8, 2010 | 10:33 AM
kdick91's Avatar
My best guess is that you have a blown head gasket and water is squeezing out at the back of the head. The fact that it happened after a cam install is coincidence.
Old Jun 8, 2010 | 10:42 AM
Paint_It_Black's Avatar
It's not a coincidence that it happened after he also did the heads though.
What gaskets did you use?
Old Jun 8, 2010 | 10:43 AM
Bo's 98 TA's Avatar
+1 and he said that he changed heads too.
Old Jun 8, 2010 | 10:48 AM
Ethan[ws6]'s Avatar
I got NEW GM factory steel gaskets and it's more than seeping it kinda just poured out. I was thinking that maybe the coolant stop or whatever they're called on the back of the head maybe loose or something. I ran it twice and drove it once before this ever happened
Old Jun 8, 2010 | 10:52 AM
69LT1Bird's Avatar
Did you put the plug in the rt cylinder head near the firewall?
Old Jun 8, 2010 | 11:04 AM
KRAZY K 2000 TA's Avatar
or the coolant crossover plugs on the heads too?
Old Jun 8, 2010 | 11:21 AM
69LT1Bird's Avatar
Yep, forgot about those, maybe you left them or one loose.
Old Jun 8, 2010 | 11:45 AM
LS1-450's Avatar
Yah, it's gotta be one or the other or even both. Get her fixed. Saturdays' Super Summit is quickly approaching. Don't wanna miss out.
Old Jun 8, 2010 | 01:13 PM
Ethan[ws6]'s Avatar
That's what it was just put it in haha. Thanks for the help everyone! Yet another problem solved thanks to the internet.
/thread
Old Jun 8, 2010 | 01:16 PM
69LT1Bird's Avatar
Sweet, glad it was easy. Remember always start with the basics, don't overlook the obvious.
