crank
Old Jun 8, 2010 | 10:03 PM
izzman55's Avatar
Default crank
alright guys so i cannot get the crank pulley bolt loose.... i already broke a smaller breaker bar, the crank is locked by a bolt so i can turn the bolt or try too.... i tried what i thought was left and nothing, today i tried the other way by hand and still nothing. so wtf. lol
izzman55's Avatar
pain in my ***....
Old Jun 8, 2010 | 10:09 PM
conan's Avatar
Are you using a 1/2" drive socket with at least a 18" braker bar? The crank threads are NOT reverse threaded, counter clock wise to remove.
Old Jun 8, 2010 | 10:15 PM
izzman55's Avatar
no i used 3/8ths and like a huge pole and the breaker end piece snapped. so im just worried it just seems like too much.
Old Jun 8, 2010 | 10:20 PM
conan's Avatar
Get your self a 1/2 inch drive set. I have even had to use a pipe extion on my 18' bar to get enough torque on some engines. If you have a buddy have him hold the the socket so it can't slip off the bolt and strip it, get the handle of the bar at 12 oclock and pull like hell from the pass side of the car.
Old Jun 8, 2010 | 10:21 PM
LS-1Z28's Avatar
that bolt's torque spec is 250ft-lbs
you're going to need some leverage on this one... consider a 1/2" drive breaker bar + cheater bar
also, how is a bolt locking the flywheel right now? I used the GM flywheel locking tool that bolts in place of the starter... worked really well . Hopefully the bolt doesn't damage the flywheel.
Old Jun 8, 2010 | 10:25 PM
93batmobile's Avatar
you should be more worried about breaking tools before breaking that bolt off lol
Old Jun 8, 2010 | 10:26 PM
izzman55's Avatar
these bolts i screwed into the end of the crank where the flywheel would be. they hold well, but wow.... i cant believe its that much.... 250ft lbs. i gota do this to take my crank out and see if its repairable one part has a ridge in it since the spun rod bearing wore it down a bit, do you guys think its repairable? its a ridge on one part.
Old Jun 9, 2010 | 11:45 AM
Gatsby's Avatar
You really have to use 1/2" drive. I just did my cam swap and broke a 3/8" 1.5" extension trying to remove that bolt. I went to lowes and got a 3" extension for my 1/2" drive and then STILL had to put a 24" breaker bar on it. Once you break it loose it's only hand tight. Such a weird feeling to put 250lbft on a bolt for 1/4 turn then its just finger tight.
Old Jun 9, 2010 | 09:25 PM
Grimes's Avatar
1/2 inch breaker bar with a 3 foot long steel pipe on the end of it. works every time....
Old Jun 9, 2010 | 09:30 PM
crainholio's Avatar
Great question. If you can tell us exactly how many bricks are in a pile, or how long a piece of string is, we can tell you whether your crank is salvageable.
Old Jun 9, 2010 | 11:35 PM
OUTLAWZ RACING's Avatar
Put alittle heat on it.
Old Jun 10, 2010 | 09:32 PM
izzman55's Avatar
got it off and apart thanks guys
