the tsunami will be here tomorrow!***updated w/ track times!***
#101
stock rear suspen ??
overall it's nothing but a street beast with alot of tenth's lost ... trap speed 115 ... i say get a 1 7/8 LT w a real clutch .... 275/35/17 NT555 R??
#103
Just curious, are you still happy with the setup? What injectors are you running and what cc did you have the heads milled to? I have this setup sitting at home and my heads are milled to 62cc. Have you been to the track again?
#104
hey 02sslayer: where are you located? i did the same heads cam build you have, but with stock intake setup, and Kooks to GMMG cat back and an LS6 clutch, the clutch couldnt handle the track but was pretty nice for streetability. i had the same problem with my transmission too, i ended up blowing my 3rd/4th synchro and shattering my 3rd gear shift key. therefor im getting a stage 5 transmission rebuild through RPMtransmissions, then to fix the rear i KNOW getting a MidWest Chassis 9" rear WILL hold anything i throw at it. we have tossed that rear between 4 cars, 2 on motor and spray, and the other 2 were supercharged
might be worth looking into if your in the midwest area. and clutch wise, i recommend a RAM clutch. Merry Build!
#105
i really like the cam, it sounds wicked. but i was a little dissapointed with the results on my dyno and track times. stock injectors, 62cc, the last time i went to the track i managed a 12.1@ 115(trap speed seems really low to me)
#106
