Normal Oil Comsumption after Cam?
Old Jan 14, 2004 | 11:19 PM
John02SS's Avatar
Default Normal Oil Comsumption after Cam?
How much oil are you guys using after cam installs. Mine didn't like Royal Purple and I now run Redline 10-30. It still uses some and I wanted to make sure this is normal. Around .75 qt in 1500 miles with some pretty tough driving (Playing with new found power) is were I'm at right now. How are your LS1's doing?
John
Old Jan 15, 2004 | 12:17 AM
Ferocity02's Avatar
I put in 6 quarts when I did my cam swap, hasn't gone down at all that I can tell after 400 miles. I put in Mobil 1 10w-30.
Old Jan 15, 2004 | 07:28 AM
DG Gordon's Avatar
Mine uses a little oil after the cam swap. But only when I run it hard, under normal driving it is ok. I am using a no synthetic Quaker State and it still uses.
Old Jan 15, 2004 | 07:59 AM
FILE's Avatar
I did not noticed any difference in oil consumption after cam install.
Old Jan 15, 2004 | 08:10 AM
BenKey's Avatar
No difference.
Old Jan 15, 2004 | 08:45 AM
gomer's Avatar
I'm still on "full" when I change my mobil 1 5w-30 at 3,000 miles. Mine has never used any oil.
Old Jan 15, 2004 | 11:56 AM
Ryan02SS's Avatar
No added consumption after my cam installs. My LS1 has never burned oil from day one. Just got luckey I guess. I am running Schaeffer 10W-30 PAO Blend.
Old Jan 15, 2004 | 12:01 PM
99-LS1-SS's Avatar
STF Veteran
Mine has never used oil either. I use Valv. 5w-30. Seems to do good.
Old Jan 15, 2004 | 01:14 PM
John02SS's Avatar
Mine didn't use a drop until the cam. It doesn't smoke on start up so i don't think I hurt the valve seals during the spring install. I used the compressor with about 100-120 psi, but don't think that would hurt anything. Tonight will install the new style PCV valve (from the trucks) and will see how that goes.
John
