Heads/Cam vs Supercharger
Yeah your right afrs and trickflow flow better than aftermarket companies that port stock heads but its not by much. PRC has heads that flow 312cfm and afrs flow about 320cfm. Yeah theirs a diffrence but for the money I would go with ls6 heads. Yes that is good about trickflow heads that you can run bigger cams but you also have to change rockers too. I would like to see the diffrence between heads (Prc 2.5 5.3 mil 59cc heads vs Trickflow heads) to see whats the diffrence In hp with same setup
Do you know how much rwhp trickflow says their heads will give you?? I know they say thats the best head you can get just want to see how much better than the rest
To the other posts above.
Hell my little patriot stage 1 h/c setup was running down 450-550 rwhp cars like crazy, it made 439 rwhp/394 trq, but had a decent curve, and was geared right. rwhp is just a number, results at the track will vary.... I like N/a and when done right will have decent low end, and instant throttle response, even with a large ish cam. DCR is improtant, tuning is important, every detail is important. When you just pick brand x cam, brand y heads, brand z intake throw it all together and expect a killer setup, you get those "why does my h/c car make 395 rwhp, and run 12.50 @ 116.
Here is the calculator we used. Remember this is just a mathmatical calculator saying you need this much power to move this much mass, at this speed in 1320ft.
http://www.wallaceracing.com/et-hp-mph.php
and i either suck when it comes to searching through someone's posts or you don't have pics up lol
So why??? So if I swap heads let say to afrs and get a fast will I see great improvement Or Night and day diffrence
