bad valve or rocker? pic inside
Since you have stock rockers, things will change a bit. Also, need to know what tools you have available to you for this check. One other thing to consider, if you only replace the bad valves without checking the rest of the valves you can run into three problems. First, the valve stem height on the replacement valves may be different then the rest. Second, the remaining valves may have the same problem in which case you will be taking the motor apart again. Third, if they valve job on the heads is special like five angle and not stock, you need someone who can provide that matching cut on the valves.
I had asked earlier whose heads these were?
