Preload.. 1 turn = .047" is this really accurate?
Old Jun 19, 2010 | 03:32 PM
vettenuts's Avatar
That's why I asked the question. The 832's have a major harmonic at 6,200 RPM. I hate telling guys bad stuff about parts they already bought though.
With that cam, I would go with the PAC duals myself.
Old Jun 19, 2010 | 06:04 PM
LIL SS's Avatar
Moderator
I have not bought the replacement 832's yet. The heads had 832's on them when I bought them used from my buddy. I tested a couple of them a few days ago and they were down to 75-80lbs at 1.80 and 300lbs at 1.15".. Since I have the retainers and seat locators for them, I planed on using them again. I'd only have to buy springs.
I can't find the 833's on Cranes web page, but Summit makes them out to be a very similar spring. Same rates (1.80 and 1.15) as well as coil bind of 1.045. Only thing I could find different about them is the spring diameters.
The truck will not be getting much mileage on it for the next couple years since I will be in school and going through the police accademy. Truck is currently non opped and with out insurance. I'll be taking it to the track 3-6 times a year at best. In between track outings, I will also be loosening the rockers to take any extra strain off the springs. I'm sure keeping some open more than others will tend to change spring rates over time.
With that said, are 832's still a bad choice? Do the 833's have better harmonics?
Old Jun 19, 2010 | 10:17 PM
SweetS10V8's Avatar
Lets break out the Spintron......Whos got one???
Old Jun 20, 2010 | 02:54 AM
LilJayV10's Avatar
Well crap. This doesn't sound as easy as I thought it was going to be.
My heads are going to be milled .025-.030 which is going to require a shorter push rod, obviously.
When you mill the heads does that have anything to do with the wipe pattern on the valve stem? Or do stock rockers on stock heads not require shims like some aftermarket heads do?
Old Jun 20, 2010 | 07:01 AM
SweetS10V8's Avatar
OEM style rockers would require shims. You cant change the wipe pattern since they are non adjustable. The only thing you change with OEM rockers and differing length pushrods is plunger depth.
Old Jun 20, 2010 | 03:46 PM
JPH's Avatar
JPH
The 833s will be a direct bolt in replacement for your 832s, and have greater seat load open/close and is much higher frequency rate spring! Trust me, you won't have any issues with these, just make there are all setup correctly.
Old Jun 20, 2010 | 08:27 PM
LIL SS's Avatar
Moderator
What are the pressures? I only find them on Summit, but they show the same pressures as the 832's.
You also say they are a direct replacement for the 832's but they show being 1.275 OD vs 1.24 and .667 ID vs .650 on Summits web page.
Is there anything on Cranes webpage giving info on them? I can't find it if there is.
Old Jun 21, 2010 | 04:29 AM
vettenuts's Avatar
833's were introduced shortly before Crane went under. I may have some information at home.
Old Jun 21, 2010 | 06:23 AM
SweetS10V8's Avatar
Have you looked into Comp 26926 duals?
Old Jun 21, 2010 | 12:01 PM
JPH's Avatar
JPH
137# @1.800
377# @1.150
369# rate
O.D.= 1.237
I.D.= .655
Max lift= .650
Old Jun 21, 2010 | 12:03 PM
JPH's Avatar
JPH
Haha, beat you Bob! You know, I got lots of LSX Crane info stuff.
Old Jun 21, 2010 | 03:31 PM
  #32
LIL SS's Avatar
Moderator
Thanks guys...
I'd have to buy more parts in order to run 926's.. Plus with a coil bind height os 1.1, I'd run in to issues even faster..
Old Jun 22, 2010 | 12:12 AM
  #33
LilJayV10's Avatar
OK I have a question w/o starting a new thread.
Tonight when I was checking PTV clearance. I did it this way using an adjustable pushrod. I used the one valve open the other closed method. Using a solid lifter I turned it until there was no slack in the valve train and it didn't open the valve. On the intake I got 7.25 and on the exhaust I got 7.0 I tightened the bolt about 1/2 turn but did not torque it down.
With adding a .047 lifter preload I get right at a 7.3 length pushrod(using 7.25). The heads have been milled and it's an aftermarket cam. Am I going to have to use two different length pushrods?
Am I going about this the right way?
Thanks.
Jason
Old Jun 22, 2010 | 04:22 AM
  #34
vettenuts's Avatar
Jason,
Confused on your question. You state you are measuring PTV but counting turns indicates you are measuring preload of the lifter.
Old Jun 22, 2010 | 11:49 AM
  #35
LilJayV10's Avatar
Jason,
I used a solid lifter and zero'd out the lash on my pushrod. I was told this was the best way to check PTV clearance. After I got done I took the pushrod out I counted how many turns it was.
Old Jun 22, 2010 | 11:56 AM
  #36
vettenuts's Avatar
OK. Solid lifter at zero lash can be used for finding PTV. You need to check the valve clearance about every 2 degrees from 20 degrees before TDC to 20 degrees after TDC on the exhaust stroke.
You can use the turns of the adjustable as long as it is the same lifter you plan to use, i.e., LS7 lifter was used for both. If the lifter is different, you may want to re-check the pushrod length with the final hydraulic lifter.
Old Jun 22, 2010 | 12:06 PM
  #37
LilJayV10's Avatar
That's what I did. I am using the same lifters. So do I take the 7.25 I have and add .047 to it? Is that going to be enough preload for the exhaust side that was only 7.0?
Old Jun 22, 2010 | 06:08 PM
  #38
vettenuts's Avatar
Not sure I follow the 1/2 turn part of your procedure. The rockers should be installed snug and the adjustable pushrod opened just until the clearance is removed.
Old Jun 22, 2010 | 06:21 PM
  #39
LilJayV10's Avatar
That's what I did. I tightened it 1/2 turn to see if it would make any difference on the preload which it didn't.
I just wanted to make sure the bolt was snug that's all.
Old Jun 22, 2010 | 07:10 PM
  #40
vettenuts's Avatar
Your measured lengths were 7.000 and 7.250? That is a really big difference. I would double check and make sure the lifter is down all the way and on the base circle.
