High compression 347 with Texas Giant?
The overlap triangle on that cam in a 346 will want peak power way over the normal 6400 where the intake wants to peak, and the heads may be running out of air or stalling bad before it ever gets there. That's why it falls off so bad. Engines don't run at 28" of water depression.
This is a mismatched pile of junk. Look at the numbers the poster above me made with a 224 cam and 243's with a valve job. I don't care if god is tuning his car, it's not going to sniff 475 with what he has. He'll be lucky with 450.
I think about 10º less duration on both sides would have been a better idea, but maybe he'll get the kinks in the combo worked out and run an ET.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Or maybe a cam ground with this in mind. Eliminating more of the overlap at lower lifts. There is nothing really wrong with big fast ramping agressive lobes, but how you set there valve events, well, that's another topic.
