High compression 347 with Texas Giant?
Old Jun 20, 2010 | 12:51 AM
2ktransam's Avatar
Default High compression 347 with Texas Giant?
A local guy here built a high compression Ls1 347 (12.5 to 1) with ported ls1 heads and a Fast 102 intake. I tried to talk him out of putting a Texas Giant cam in it being stock displacement but he did it anyway. My buddies shop tuned it and only made 430rwhp through a M6. This guy is saying that something is wrong with the tune and it should have made more power but I think it is because the parts are so mis-matched. What do you guys think? I think he would have made more power with a smaller cam that was cut for the 346 instead of a stroker motor.
Old Jun 21, 2010 | 09:01 AM
TermnEatr's Avatar
other than the cam he needs to ditch the 102 and shoot more for a 90 or 92 combo the 102 is overkill on a 346 imo
Old Jun 21, 2010 | 11:17 AM
RedHottG2's Avatar
The FAST 102 is fine imo because the LS motor is only going to pull in as much air as it needs. That's why FAST only makes the 102 now. It has to be the cam, he needs something more suitable for the 346 and he should see nice numbers.
Old Jun 21, 2010 | 01:11 PM
TooLateVTEC's Avatar
I think the stock LS1 heads are holding him back. You said they're ported but just like a hand job clean up or a full on CNC or what?
Old Jun 21, 2010 | 03:10 PM
MeanGreen's Avatar
I too think its the heads that is holding him back.
Old Jun 21, 2010 | 03:19 PM
5.3LJimmy's Avatar
I'm going to have to jump on the bandwagon and blame the heads as well. That thing will need to turn some serious RPM to reach the HP peak with that cam. The heads and valvetrain need to be up to the task.
Old Jun 21, 2010 | 03:26 PM
LIL SS's Avatar
Moderator
Can you give us info on the full build? For all we know it has 1 5/8 shorty headers on it.
Was it through full exhaust? What was the exhaust.
How'd the AFR look?
Was there gain seen adding/subtracting timing?
Could be the heads.. Could be the valve train.. Could be lots of stuff.
Old Jun 21, 2010 | 03:33 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
That's Jared's build, right? What heads did he put on there and what headers/exhaust?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 21, 2010 | 03:34 PM
1SLwLS1's Avatar
Need more info on the heads. I ASSuME forged rotating assembly, etc. Flat tops? Dome pistons? How did he get to 12.5:1 milling heads? the pistons?
The power seems right on for stock-ish heads.
Old Jun 21, 2010 | 05:37 PM
AznMuscle's Avatar
With un touched 243 heads, ls6 intake, ported stock tb and stock bottom end (stock compression ratio), my car did 423. With ported heads and more comp, I would assume more power. That FASTwith that high reving wanting cam, I would think ~450. Street manners would probably suck though...
Old Jun 21, 2010 | 06:04 PM
LIL SS's Avatar
Moderator
Everyone talks about street manners sucking with big cams.. I find it funny as can be. My little single plain wearing Trexed 347ci motor with 11-1 cr fires up with out and throttle and goes right to idle weather it's hot or cold out. Idle's at a solid 850-900 rpm. Doesn't surge even at 1800rpm with the converter locked. But hey, I guess that means it has horible street manners..
westtexasbuff's Avatar
I luled when I read this.
Old Jun 21, 2010 | 06:19 PM
Darkman's Avatar
Gotta love this thread - the cam ain't too big, everything else (heads, exhaust, etc.) is just too small.
Old Jun 21, 2010 | 10:01 PM
nysbadmk8's Avatar
Cam is also ******* huge for a 346cid, **** I have this cam In my 402 and its big!
Old Jun 21, 2010 | 10:41 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, that cam is going to bleed off some of that compression.
Old Jun 22, 2010 | 01:06 AM
2ktransam's Avatar
This is Jared's build. The heads are stock ls1 castings that supposedly have been cnc'd and hand ported. I don't know the flow numbers but its hard to tell with stock castings and local guy doing the porting. He has Edlebrock 1 3/4 stepped to 1 7/8 headers going into a Loudmouth exhaust. AFR was around 12.8 and the timing didn't seem to help it any. We started at 22 degrees and went up to 26 and he only gained 4hp so we left it around 24 which seems low to me. I run 29 degrees on pump gas in my 402 but his car didn't seem to like the extra timing. The power was rolling over buy 6400 so something is killing his airflow quick. I would think the texas giant would pull into the 7000 range on a 346 if it was setup right. My guess would be the heads are holding him back. The reason I don't like this cam for his car is that it has nothing down low and this is in a stick car so it will have horrible street manners.
PS I don't have anything against the texas giant since it is in my 402 but I think his setup is just mismatched.
Old Jun 22, 2010 | 03:13 AM
ssntmre66's Avatar
From what I was told they were ported by "some local guy" and they are flowing something like 340 CFM? But from everythiing I have read about LS1's isnt there something special to porting them compared to a standard SBC and BBC head? Also I love whe guys talk about PEAK flow when its easy to forget about velocity and flow throughout the entire lift range...
Old Jun 22, 2010 | 08:27 AM
1SLwLS1's Avatar
I would also guess heads. They could be fubar if the wrong person got a hold of them. The intake seems good, and although the cam is huge for the displacement, something is wrong if he falling off hard after 6400.
Street manners is all in the tune and completely dependent upon the driver. I can tolerate quite a lot. The MS4 is still a large cam for the 346 and it has great street manners. If it wasn't for my cylinder 7 ring being fucked up, it would drive perfect in all weather conditions. Starts right up, idles around 1000-1150 when cold and around 850-900 when warm. Whenever I clean the intake (read cylinder 7 ring problem), it runs like a dream, no idle hunt, and I never buck or surge.
Old Jun 22, 2010 | 02:27 PM
AznMuscle's Avatar
I have a relatively large cam (242/248 111 lsa), and what I mean by street manners is always driving over 2k rpms, idle dropping when coming to a quick stop, ac at lights (when not fully warmed up) likes to low idle, making slow turns likes to drop idle....well my car at least. Bucking and surging is a issue, but if you drive the car how you should with a large cam, it can be avoided. Mine does not go straight to idle, it likes to cold idle..but...4600 elevation does that. In Phoenix my cam acts a lot better then where I am at currently.
Old Jun 22, 2010 | 02:46 PM
1SLwLS1's Avatar
Yea thats altitude and tune. My tuned MS4 has no problems with any of that. My only problem is with clutch engagement and the stock rear gears. Are you returning to Phoenix or staying where you are?
