degree wheel kit recommendation
It doesn't come with the light weight checker springs though. I was surprised by that.
Mine didn't come with the foam case like it was suppose to and i for some reason they sent my the BIG degree wheel not the small one listed in the ad.
I keep meaning to call summit and see if I can get the plastic box to put the stuff in so I don't loose everything.
The only complaints I have about the kit is this...
It didn't come with checker springs.
It didn't come with a box, which very well may be a fluke since I was one of the first orders.
There is not way to adjust the dial indicator to run parallel with the valve. (Which I don't know if it's even an issue)
The lack of some basic instructions on how to set up the kit.
To use the magnetic base, I used a piece of angle iron from the hardware store to make a bracket that bolted onto the header flange which provided a flat surface to secure the base. It ended up workng out really well.
You have no idea what you are talking about. My custom cam I just put in was 3 degrees off on the ICL.
Please don't spread misinformation.
