Question for on heads..................?
Old Jun 27, 2010 | 09:09 PM
pstexas2's Avatar
Default Question for on heads..................?
Ok im fixing to do h/c swap on my 99 camaro ss but not sure if either going with the prc stage 2.5 5.3 heads, or going with the prc ls6 2.5 heads. I know there both flow really good but which ones would give me most rwh? If im going with ms4 cam and ls6 intake:d
Old Jun 27, 2010 | 09:43 PM
pstexas2's Avatar
Thumbs up
Anyone
Old Jun 28, 2010 | 06:34 AM
batboy's Avatar
Either one will work good. Pick up the PRC stage 2.5 5.3 heads if you're on a tight budget. The PRC stage 2.5 LS6 heads will flow a little bit better.
Old Jun 28, 2010 | 06:54 AM
odarabla's Avatar
Those 5.3 heads will work fine but if you ever decide to put a bigger motor in it you will need a new set of heads.
Old Jun 28, 2010 | 09:55 AM
SOMbitch's Avatar
Neither of those cams will work with an MS4. MS4 will clear stock sized valve 243's but the stage 2.5 LS6 heads have oversize 2.02/1.57 valves.
The 5.3 stage 2.5 heads will clear a MS3 if TSP sets them up for it (increased valve drop) but not a MS4.............
Old Jun 28, 2010 | 11:07 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
You hit the nail on the head. Unless the OP is willing to flycut the MS4 will not fit with either of those heads. If you are looking for a cam close to the MS4 that will fit you might consider our Tsunami cam. It has a little less duration which allows for more piston to valve clearance.
Old Jun 28, 2010 | 11:18 AM
odarabla's Avatar
****! Didn't think about the PTC!!
Old Jun 28, 2010 | 12:05 PM
drewwrxrogers's Avatar
Nobody ever does
Old Jun 28, 2010 | 07:06 PM
pstexas2's Avatar
Thanks for the info guys yall really helped me out a lot guys I'm gonna got with the prc ls6 stage 2.5 heads and ms3 cam hopefully I get the 400+ rwhp range.
Old Jun 28, 2010 | 10:19 PM
jebuzws6's Avatar
I dont think that set up will clear either...
Old Jun 28, 2010 | 10:28 PM
SOMbitch's Avatar
He just needs to call Jon, John or Matt when he places his order and they will steer him right.......
Old Jun 28, 2010 | 10:41 PM
Paint_It_Black's Avatar
It won't unless it's set up for it.. and TSP does modify their heads with that package by sinking the valves. Keep in mind though, this will change the installed height of the springs (because unless they shorten the stems they will sit higher), so it will effect rocker wipe, spring pressure, and push rod length.. so make sure you measure and check all of that.
Old Jun 28, 2010 | 11:11 PM
pstexas2's Avatar
Damn I figured I would of been good on the ptv clearance a buddy of mine is running some prc stage 3 heads and a ms4 cam on his 2001 ss stock motor, Idk how his car is still running but it is lol
Old Jun 28, 2010 | 11:12 PM
pstexas2's Avatar
Damn I figured I would of been good on the ptv clearance a buddy of mine is running some prc stage 3 heads and a ms4 cam on his 2001 ss stock motor, Idk how his car is still running. right but it is lol
Old Jun 28, 2010 | 11:13 PM
pstexas2's Avatar
Damn I figured I would of been good on the ptv clearance a buddy of mine is running some. Ls6 prc stage 3 heads and a ms4 cam on his 2001 ss stock motor, Idk how his car is still running. right but it is lol
orangeapeel's Avatar
ЯєŧąяĐ Єlmиąŧя
Its probably not a stage 3 then.
Old Jun 28, 2010 | 11:21 PM
pstexas2's Avatar
That's what I said till he show me the receipts
Old Jun 28, 2010 | 11:24 PM
ЯєŧąяĐ Єlmиąŧя
LOL forget that. Show me the valves! is what you should be asking.
Old Jun 28, 2010 | 11:30 PM
pstexas2's Avatar
Lol shure will
