oil problems, burning too much and car idling terrible
yeah i knew the definitions to the codes i just didn't feel like typing them out haha
well the car is fixed...or at least i hope so...
changed out the o2 sensors, cleaned the MAF, and checked all of the plugs and wires to make sure they were snug.
turns out a few of the plugs were somewhat loose and i could freely twist/wiggle them while they were attached to the block.
so far everything has been running fine and i am having no issues...i just pray it stays that way
well it wasn't that bad and it was things i need to check regardless since i'm going out of town here in the next few weeks to austin for heatwave. better to fix things here than have something go wrong out there.
thank you for all of the help
most definately will do.
o hey...and one more quick question...what tool do i need to take off the top pulley on the ac belt? i know there's 4 pulley's:ac, tensioner, crank, and it's the other one that i need to check to see if it needs replaced i just don't know what tool to use
