LS6 to 383 stroker question
Old Jul 1, 2010 | 01:10 PM
Hanzy98LS1's Avatar
Default LS6 to 383 stroker question
I'm not real familiar with the stroker kits but I whant to install it my question is am I going to have any machining or fab to the block or can I just buy it and bolt it all straite in?? Thanks
Old Jul 1, 2010 | 01:29 PM
SOMbitch's Avatar
Yes the block will need to be clearanced and have your crank jounals checked to see if they need cleaning up...
Old Jul 1, 2010 | 01:36 PM
eduardo's Avatar
So how much money does it typically cost to do a 383 stroker kit. I'm I terested in this too.
Old Jul 2, 2010 | 12:59 PM
Hanzy98LS1's Avatar
Well I know TSP has a kit for 1600 an some change but what I'm tryin to figure out is what kind of clearences il need done so I can get an idea of what itl cost to have it machined preped an ready to install.
Old Jul 2, 2010 | 01:38 PM
sbsrkh's Avatar
I'm putting together a 383 right now. The cylinders will need to be honed to 3.905, along with any other normal machining you need (install cam bearings, check the mains, etc). The only special clearance for a 383 would be the bottom of the cylinders so the rod bolts don't hit. Some need more than others. My bolts pass, but I'm going to remove a little more to be safe. I bought a Callies kit from Thunder racing. It's a little more money than an eagle or scat kit, but from everything I read, there have been less problems with them being out of spec.
Here's part one of a 4 part article from GM hightech mag that shows the clearance issue:
http://www.gmhightechperformance.com...ild/index.html
Old Jul 2, 2010 | 11:02 PM
Hanzy98LS1's Avatar
Awesome link man thanks that's what I was lookin for!! Next step and probly the hardest finding a machine shop lol thanks guys for your info!
